Hi,
I had to re-setup my HS server due to a HDD failure. I have been trying to re-setup my Modbus interface, but most of the time, the point is added to HS, but does not show up under the modbus i/f. If the point does show up, it often dissapears after. The data from the points seem to transfer during the time that the HS Server is running, but in the log it says polling 0 points, whereas I have almost 10 points defined.??
