Hello Gavin
We have to thank you very much, the plugin works perfectly even if the setting is not easy. We used the plugin to connect a Daikin air conditioning system to HomeSeer and after many tests and after verifying that it only works through virtual ports we found a way to make it work well. We used an RS485 to Ethernet converters USR-TCP232-304 and it works very well. To set the Holding Registers and Input Registers we had some problems but then we found the solution. The plugin works perfectly with HS3 and we will be testing it with HS4 soon.
Thanks, Thanks
Massimo-RenderCAD
Thanks, Thanks
Massimo-RenderCAD
