Hello Gavin
We have to thank you very much, the plugin works perfectly even if the setting is not easy. We used the plugin to connect a Daikin air conditioning system to HomeSeer and after many tests and after verifying that it only works through virtual ports we found a way to make it work well. We used an RS485 to Ethernet converters USR-TCP232-304 and it works very well. To set the Holding Registers and Input Registers we had some problems but then we found the solution. The plugin works perfectly with HS3 and we will be testing it with HS4 soon.
Thanks, Thanks
Massimo-RenderCAD
Modbus over TCP/IP?
Hello
Unfortunately until now I have not yet had an answer to my question but, on this forum it had never happened. However I solved by myself, I forgot a warning in the RTD-NET card manual which I report here: "RS485 Cables must use stranded 24awg shielded or unshielded twisted pair to Cat3, Cat4 or Cat5 specification. Use a twisted pair for connections DB, DA and an extra core for connection GND .... "I did this and it was fine. I hope it helps someone to avoid the mistake I made by using the wrong cable..
Massimo-RenderCAD
Originally posted by beerygaz View PostYup - it will work for you. Download the trial when you get it all hooked up and give it a try, but from the manual it looks to be pretty straightforward.
I have installed the RTD-NET card and the RS 485 converter and they seem to be connected well. The IP address of the converter is found well but the card is only receiving data (RX) but is not transmitting data (TX). I also tried to use the serial port through a VSPE virtual converter but the problem remains the same. I attach reference images and log files. Where could we go to investigate the issue? Thanks
Massimo-RenderCAD
Hello
I hope it is the right place to ask this question. (I apologize if I don't write very well in English, forgive me if I make some mistakes.)
I'm buying a Daikin air conditioner with internal piping distribution that uses this RTD-NET card that I send as an attachment (file pdf). I will also use an RS485 to ethernet converter (image2). With this configuration, is it possible to use this "Modbus plugin" to manage my DAIKIN FBA60A air conditioning in HS3 PRO? Thanks
Max-RenderCAD
HS3 Pro Edition 3.0.0.548 (Windows)Plug-Ins Enabled: Device Comparison 3P:,NetCAM:,Restart:,Arduino Plugin:,Global Cache Pro:,BLVolume:,BLBackup:,APCUPSD:,EasyTrigger:,Device History:,PHLocation:,Z-Wave:,Current Cost 3P:,BLDatabase:,MyZWaveParameters:,ADIO-100:,SDJ-Health:,AK Google Calendar:,mcsMQTT:
Originally posted by Moskus View PostThanks for the tip!
My new ventilation system is also from Systemair, so any help would be appreciated!
(I have absolutely no knowledge of Modbus...)
The option in the manual says "Modbus Gateway TCP-RTU/RS485 mode switches the IAM to Modbus TCP converter mode"
Originally posted by Fandre View PostHi,
I communicate over modbus TCP/IP with this plugin. I have bought a USR-TCP232-410S from Aliexpress which converts modbus RTU (RS485) over to TCP/IP.
Originally posted by John245 View Post
In my case the multiplier is working. When i multiplie with 0,1 it will divide correctly.
John
I communicate over modbus TCP/IP with this plugin. I have bought a USR-TCP232-410S from Aliexpress which converts modbus RTU (RS485) over to TCP/IP. My ventilationsystem is Systemair and is working perfectly fine to control everything from heatexchanger to airflow, reading temperatures and so on.
The only thing I am waiting for is the developer to fix the multiplier-bug as it will not scale down, only up. For example; a reading of 190 in extract temperature can not be scaled to 19 yet.
John
Originally posted by Moskus View PostPerfect! Which ones are these (the working ones)?
I have a KOICONTROL modbus TVP over IP device and an AD converter (exact model not known by head) over TCP/IP.
I now the author is bussy with a re-write which will solve a lot of issues.
John
Originally posted by Moskus View PostIs it possible with this plugin? And what interface do I need?
I've soon got a new ventilation system up and running. The old Z-wave interface for this system does not work anymore, so Modbus is the way to go. I have ethernet access where it is installed.
I also have multiple devices were I use a RS232-RS485 converter in combination with a serial server.
John
