I'm struggling with getting this plugin to work with PZEM-014/016 AC power energy modules. However, I got it working correctly on a program called 'Simply Modbus Master'.
Gateway physical layer setting are set as per instructions (9600,8,1,no parity) with a device using 04-Input Register with register address 1. However I get following:
Error in ReadValue: Checksums failed to match 1, 144, 9 != 1, 144, 9, 212, 82
Error in Read: Checksums failed to match 1, 144, 9 != 1, 144, 9, 212, 82
Read error for Energy-Volts
and so on..
On Simply Modbus Master, I get the following and seems to work fine without any hardware, driver changes (obviously plugin disabled)
I've attached trace log of plug-in.
Any suggests?
I am a novice at modbus, so please be kind :-)
I read this plugin is due for re-write. When is this likely to be completed? I've just purchased and feel a little disappointed it's not working.
and so on..
Any suggests?
