Hi beerygaz,
I'm using your plugin to read Modbus data form a SMA sunnyboy 3.0 Solar Inverter..
At nighttime a couple of registers are not accessible. This will generate errors in the logfile.
In the device tab "Modbus" you can enable / disable a Modbus device.
Is it possible to add something to your software to make it possible to enable/disable the Modbus device from a HomeSeer event, just like the Modbus gateway?
Best regards,
Hans
Best regards,
Hans
