Plugin not shown as installed
  • amarcuvitz
    Workaround that appears to work:
    1. Install the free MyQ plugin.
    2. Install the ModBus plugin. It will say the install was successful but it will not show as installed.
    3. Find the NLog.dll file in the folder /usr/local/HomeSeer/bin/HSMyQ and make a copy of it in /usr/local/HomeSeer/Updates3/Modbus3.9.6431.26038
    4. restart Homeseer and the ModBus plugin should should show as installed.
  • amarcuvitz
    I found the following:
    Originally posted by JoelWener View Post
    I got the Modbus pluggin to work by copying the version of Nlog.dll, and Nlog.assemblies.dll files from the MyQ folder (pluggin) under HomeSeer to the HSPI_Modbus directory. It seems the NLog.dll file coming with Modbus pluggin is too old, and is not compatible with newer OS.
    MyQ is a free plugin that you can install. Nlog appears to be a linux logging library. Not good that the ModBus author is MIA and people are wasting all this time and some may give up on HS altogether.
  • dhoon
    Hi, I faced the same situation, cant find the Modbus plug-in in the plg-in manager
    kindly reply as we need to confirm before buy
  • jcamm3
    Same here as well
  • amarcuvitz
    I have attempted to try this plugin on HS3 and HS4 and experienced the same problem.
  • franksor
    started a topic Plugin not shown as installed
    Added plugin, install completed, no Modbus plugin shown in Pluin Manager. Tried on HS3 and HS4 same result.
    7/27/2020 20:09:47 HomeSeer Error Examining properties on plugin (2) HSPI_MODBUS.exe: Unable to find assembly 'NLog, Version=4.0.0.0, Culture=neutral, PublicKeyToken=5120e14c03d0593c'.
    7/27/2020 20:09:45 HomeSeer Updater Extraction Complete.
    7/27/2020 20:09:45 HomeSeer Updater Extracting files from zip file: Modbus_Graphics.zip
    7/27/2020 20:09:45 HomeSeer Updater Extracting files from zip file: Modbus_HELP.ZIP
    7/27/2020 20:09:45 HomeSeer Updater Copying file: /usr/local/HomeSeer/HSPI_MODBUS.exe
    7/27/2020 20:09:45 HomeSeer Updater Copying file: /usr/local/HomeSeer/HSPI_MODBUS.exe.config
    7/27/2020 20:09:45 HomeSeer Updater Copying file: /usr/local/HomeSeer/bin/HSPI_MODBUS/NModbus4.dll
    7/27/2020 20:09:45 HomeSeer Updater Copying file: /usr/local/HomeSeer/bin/HSPI_MODBUS/NLog.dll
    7/27/2020 20:09:45 HomeSeer Updater Update hspi_modbus.exe downloaded successfully
    Version
    HS4 Standard Edition 4.1.2.0 (Linux)
    License Registered
    License ID xxxxx
    MyHS Subscription Basic
    Uptime 0 Days 3 Hours 27 Minutes 51 Seconds
    Device Count 44
    Plugins Enabled Z-Wave:,RFXCOM:,JowiHue:
    Modules/Threads 81 Modules, 54 Threads
    Available Threads 399
    HomeSeer Memory Used 115 Mbytes
    Plugins Installed JowiHue 2.1.1.1,RFXCOM 30.0.0.41,Z-Wave 3.0.2.234
    Frank
