Open ttyr0 port under linux
    Testing the PI under Linux. The serial interfaces that I can select for example is /dev/ttyS0. However the data is on Port ttyr0.
    Running under Ubuntu 20.04 LTS.
    How can this be solved?
    John
    How are you connecting the hardware serial device to the RPi? Are you connecting directly to the RPi pins to a TTL to RS-232 device?
    Googling read that a Rocket Port modem RS-232 connection would appear as a ttyRX connection under dev.
    - Pete
    Auto mator
    Fanless Intel® Celeron N3160 SoC 8Gb
      To be clear.
      I i'm running Ubuntu 20.04 LTS in a VM. Hardware connected using a Moxa Serial server.
      Moxa solved the ttyr0 ttyS0 issue.
      At least it is working in Node-Red, but not in the Modbus-PI.
      John
        I am not familiar with the ModBus-Pi and never have utilized a Moxa serial server.
        Thinking I paid some $20 for the 1 watt LoRa serial modems mentioned above (from China) which appear to be similiar to the Moxa serial server.
        Each modem has an RS-232 port on it.
        - Pete
        Auto mator
          The Moxa's one are good. Even better than the VSCOM devices. Issues that I had with the VSCOM devices I did never see after the switch to Moxa.
          John
            Curious what are you using the Moxa serial servers for?
            - Pete
            Auto mator
              3 x PV inverter
              Heating Pump
              audio and video equipment
              John
                beerygaz
                I can read the data on port /dev/ttyS0 using Node-RED, Modpoll. However your plug-in indicates unreachable.
                As this is a test environment migrated from Windows nothing is changed.
                Any idea how to fix?
                John
