beerygaz
I can read the data on port /dev/ttyS0 using Node-RED, Modpoll. However your plug-in indicates unreachable.
As this is a test environment migrated from Windows nothing is changed.
Any idea how to fix?
John
Open ttyr0 port under linux
Originally posted by Pete View PostI am not familiar with the ModBus-Pi and never have utilized a Moxa serial server.
Thinking I paid some $20 for the 1 watt LoRa serial modems mentioned above (from China) which appear to be similiar to the Moxa serial server.
Each modem has an RS-232 port on it.
John
Originally posted by Pete View PostHow are you connecting the hardware serial device to the RPi? Are you connecting directly to the RPi pins to a TTL to RS-232 device?
Googling read that a Rocket Port modem RS-232 connection would appear as a ttyRX connection under dev.
I i'm running Ubuntu 20.04 LTS in a VM. Hardware connected using a Moxa Serial server.
Moxa solved the ttyr0 ttyS0 issue.
At least it is working in Node-Red, but not in the Modbus-PI.
John
Testing the PI under Linux. The serial interfaces that I can select for example is /dev/ttyS0. However the data is on Port ttyr0.
Running under Ubuntu 20.04 LTS.
How can this be solved?
John
Tags: None
