test 3.5.5868.34556
  • John245
    Originally posted by John245 View Post
    Beerygaz,
    Great to hear that you are working on it together with HST.
    Do you have the Proof of Principle that the events are working with the limitation of the large increments?
    For my application I don't need the large range but I understand that you would like to support that large range. Which range can currently supported with increments of 1?
    John
    Hi Beerygaz,
    Currently my workaround is calling the CAPI handler by means of a script. For me this is acceptable as I only have a couple of settings that I want to change based on a condition.
    I will be happy when you add the "read delay" to the write function in the next release.
    John
  • John245
    12.8 degrees Celsius will be to cold for the living room [emoji1]
  • beerygaz
    Sure. If I reduce the range to -128 to 128 then single digit increments are possible.
  • John245
    Originally posted by beerygaz View Post
    John I see your issue. And I'm struggling with an HA3 limitation right now, that if I allow you set the device value for such a large range -33k to +33k the value can only be set in increments of 256. I'm working with HST on a solution.
    Beerygaz,
    John
  • beerygaz
  • John245
    Hi Beerygaz,
    Do you mention an event as below? If the event below is not as intended can you give an example of the event?
    This will change the status to 200. But will not write the value to the register address. The result is that the next read is the initial value (203), see the log below.
    Feb-08 21:11:10 Modbus Debug Updating device [47398] - Address:47398 - Type:HoldingRegister(Int16) to [203]
    Feb-08 21:11:10 Modbus Debug Read Slave: 1 Address: 47398 HoldingRegister:Int16 as 203
    Next read
    Feb-08 21:11:08 Modbus Debug Reading Slave: 1 Address: 47398 HoldingRegister:Int16
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 43420 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 43009 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 43005 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 40083 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 40081 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 40079 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 40033 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 40016 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 40015 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 40014 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 40013 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 40012 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 40008 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug *Disabled* Slave: 1 Address: 40004 HoldingRegister:Int16 as 0
    Feb-08 21:11:08 Modbus Debug Polling Modbus RTU Gateway. Reading 15 registers from slaves
    Run event (set status value to 200)
    Feb-08 21:08:13 Event Event Trigger "po Modbus 47398"
    Feb-08 21:08:13 Event Event po Modbus 47398 triggered by the event page 'Run' button.
    John
  • beerygaz
    John, why not just create a device and use an event to set the device value?
  • John245
    It's in the updater now.
    Hi Beerygaz,
    Great support, this fixed the issue.
    You wrote:
    I'm worried the "read after write" may be too quick for your device, if it presents an issue, let me know and I'll add the "read delay" into the process between the write and read action.
    Today 03:39 PM
    In some cases I did get a Error in Read: The operation has timed out. So I will be happy if you can add the "read delay".
    In previous versions you mentioned the support of events. This is not mentioned in the current help file. Do you intend to support an event to write a value to a register address. This will be very useful in my case but also for users controlling a Modbus Thermostate. For e.g. in case an event is available to write a setpoint to a register address HS3 can automatically lower the temperature in the evening when it is time to go to bed.
    John
  • beerygaz
  • John245
    Thanks.
    Also the help file is looking great.
    Will test it when the next release is available.
    John
  • beerygaz
    Found it. Fixed it.
  • John245
    Sorry, I just realised the latest version was not pushing through to the updater properly. check the updater for 3.6.x.x - that should fix your issue, add a proper help file, etc.
    Hi Beerygaz,
    The interface is looking good.
    I'm sorry to report that it is still not working.
    The Log (debug) showed the following when I want to submit a value of 201:
    Feb-08 17:52:09 Modbus Debug Updating device [47398] - Address:47398 - Type:HoldingRegister(Int16) to [200]
    Feb-08 17:52:09 Modbus Debug Read Slave: 1 Address: 47398 HoldingRegister:Int16 as 200
    Feb-08 17:52:07 Modbus Debug Reading Slave: 1 Address: 47398 HoldingRegister:Int16
    Feb-08 17:52:05 Modbus Writing Slave: 1 Address: 47398 HoldingRegister:Int16 as 201
    Write value 201:
    Feb-08 17:51:57 Modbus Debug Updating device [47398] - Address:47398 - Type:HoldingRegister(Int16) to [200]
    Feb-08 17:51:57 Modbus Debug Read Slave: 1 Address: 47398 HoldingRegister:Int16 as 200
    Feb-08 17:51:55 Modbus Debug Reading Slave: 1 Address: 47398 HoldingRegister:Int16
    Initial value 200
    Using the RS-232 sniffer I noticed that only the following is written to the register:
    01 10 B9 26 00 02 04 00 C8 00 00 AF F4
    01 03 B9 26 00 01 40 9D
    C8 = 200. So it seems that in this version also the current status is written to the register address.
    John
  • beerygaz
  • John245
    Beerygaz,
    I noticed that you changed the writing of the value.
    In the new situation:
    Writing of Address to holding register followed by a read of that holding register.
    In the old version it was "working" when I submitted the new value 2 times within a short interval.
    The new situation is I think a better method to submit new values. But according to the Debug log and RS-232 sniffer the old value is submitted.
    Looking forward to test the fix.
    John
  • John245
    test 3.5.5868.34556
    Beerygaz,
    Yes I m running the latest version .
    I noticed that you made some changes,
