Error downloading Plugin - Modbus
  • OEC BOWMAN
    Plug in Install Issues
    When I try to install this Plug In I get the following in my Log,
    Mar-04 12:24:10 PM Updater Install/Update of package Modbus failed.
    Mar-04 12:24:10 PM Updater Error Installation of package Modbus failed. Try disabling the plugin first, then re-try the update.
    Mar-04 12:24:10 PM Updater Error This package requires version 3.0.0.220 of HomeSeer, and you have version 3.0.0.208 so the installation will not continue.
    Mar-04 12:24:10 PM Updater Installing package Modbus
    When I go to the Setup page it says
    Current version is: HS3 Pro Edition 3.0.0.208 No updates available. How do I get this updated?
    I am currently connected to the SEL-PRO directly with a monitor, keyboard, and mouse.
  • beerygaz
    I'll fix the installer for future versions.
  • beerygaz
    Ok. I see the issue. Please rename bin/HSPI_MODBUS/NLOG.DLL to NLog.dll
  • Raindrop
    same issue - same error with the latest version
    eb-29 4:20:32 PM Error Examining properties on plugin (2) HSPI_MODBUS.exe: Object reference not set to an instance of an object
    Feb-29 4:20:29 PM Updater Install/Update of package Modbus was successful.
    Feb-29 4:20:29 PM Updater Extraction Complete.
    Feb-29 4:20:29 PM Updater Extracting files from zip file: Modbus_Graphics.zip
    Feb-29 4:20:29 PM Updater Extracting files from zip file: Modbus_HELP.ZIP
    Feb-29 4:20:29 PM Updater Copying file: \usr\local\HomeSeer\HSPI_MODBUS.exe
    Feb-29 4:20:29 PM Updater Copying file: \usr\local\HomeSeer\HSPI_MODBUS.exe.config
    Feb-29 4:20:29 PM Updater Copying file: \usr\local\HomeSeer\bin\HSPI_MODBUS\NModbus4.dll
    Feb-29 4:20:29 PM Updater Copying file: \usr\local\HomeSeer\bin\HSPI_MODBUS\NLOG.DLL
    Feb-29 4:20:28 PM Updater Installing package Modbus
    Feb-29 4:20:28 PM Updater Update HSPI_MODBUS.exe downloaded successfully
  • beerygaz
    For reference:
    /HSPI_MODBUS.exe
    /HSPI_MODBUS.exe.config
    /bin/HSPI_MODBUS/NLog.dll
    /bin/HSPI_MODBUS/NModbus4.dll
  • beerygaz
    Can I ask you to grab the latest version form the updater and try that please. I think all the files are now named correctly. I've just tested on my Raspberry Pi and the plugin is running.
  • Raindrop
    Error on two SEL's
    By the way, We are getting this same error on two different SEL's on two different networks/locations
  • Raindrop
    "Successful Install" yet Plug in does not show up to Manage
    Despite getting a install update successful message the Plug in still does not show up int he installed plug-ins --?? Below is the error log.
    Feb-29 8:49:19 AM Error Examining properties on plugin (2) HSPI_MODBUS.exe: Object reference not set to an instance of an object
    Feb-29 8:49:16 AM Updater Install/Update of package Modbus was successful.
    Feb-29 8:49:16 AM Updater Extraction Complete.
    Feb-29 8:49:16 AM Updater Extracting files from zip file: Modbus_Graphics.zip
    Feb-29 8:49:16 AM Updater Extracting files from zip file: Modbus_HELP.ZIP
    Feb-29 8:49:16 AM Updater Copying file: \usr\local\HomeSeer\HSPI_MODBUS.exe
    Feb-29 8:49:16 AM Updater Copying file: \usr\local\HomeSeer\HSPI_MODBUS.exe.config
    Feb-29 8:49:16 AM Updater Copying file: \usr\local\HomeSeer\bin\HSPI_MODBUS\NModbus4.dll
    Feb-29 8:49:16 AM Updater Copying file: \usr\local\HomeSeer\bin\HSPI_MODBUS\NLOG.DLL
    Feb-29 8:49:16 AM Updater Installing package Modbus
    Feb-29 8:49:16 AM Updater Update HSPI_MODBUS.exe downloaded successfully
    Feb-29 8:49:14 AM Updater Downloading update: Modbus
    Feb-29 8:49:14 AM Updater Starting download of updates
  • Raindrop
    Fiddled wth case of hspi_modbus
    I tried HSPI_MODBUS.exe and HSPI_Modbus.exe. Neither seemed to do the trick. The other plugins we have installed uses one of those two case formats.
  • beerygaz
    No. If the plugin is not showing up at all then it's likely to be names incorrectly. I'm not in front of my PC right now, but try fiddling with the case of the hspi_modbus.exe file.
  • Raindrop
    Files are copied - what about ini file?
    We manually unzipped and copied the files according to the install.txt. Homeseer still isn't showing the plugin available in the web interface. The last line of the install.txt appears to create an ini file. What should the contents of that file look like? Would that cause it not to show in the web interface?
  • beerygaz
    Raindrop this looks like a Linux case-sensitivity issue. You can try to manually extract the ZIP file and copy the .config file by hand or give me a few days to get a fixed version into the updater.
  • Raindrop
    started a topic Error downloading Plugin - Modbus
    getting the following error attempting to download the Modbus Plugin
    Feb-17 11:18:14 AM Updater Error, package file not found: /usr/local/HomeSeer/Updates3/Modbus3.6.5882.34568/HSPI_MODBUS.EXE.config
    Feb-17 11:18:14 AM Updater Copying file: \usr\local\HomeSeer\HSPI_MODBUS.EXE.config
    Feb-17 11:18:14 AM Updater Copying file: \usr\local\HomeSeer\bin\HSPI_MODBUS\NModbus4.dll
    Feb-17 11:18:14 AM Updater Copying file: \usr\local\HomeSeer\bin\HSPI_MODBUS\NLOG.DLL
    Feb-17 11:18:13 AM Updater Installing package Modbus
    Feb-17 11:18:13 AM Updater Update HSPI_MODBUS.exe downloaded successfully
    Feb-17 11:18:13 AM Updater Downloading update: Modbus
    Feb-17 11:18:13 AM Updater Starting download of updates
