Supported hardware by Modbus PI
    The purpose of this thread is to list (in alphabetical order) all hardware supported by the Modbus PI. You will get an idea of hardware available on the market. If you use hardware in combination with the Modbus PI and it is not listed, please add as much as possible information and I will update the list.
    Nibe Modbus 40 communication module
    Manufacturer: Nibe
    Device type: Communication module
    Model: Modbus 40
    Test results:
    Tested with: Modbus PI v3.7.5894.16328 (serial RTU master); Nibe F1245-10 PC (FW 7113R3)
    Functionality tested: read-out Holding Registers; write to Holding Registers
    Limitations:
    Function 0x2B not supported by Modbus PI
    Notes:
    Simultaneously up to 53 addresses tested (with a poll interval of 5 minutes)
    SunMaster to Modbus-RTU converter
    Manufacturer: CEL-MAR
    Device type: Converter
    Model: ADA-4040-PC3
    Firmware: 008
    CPU version: 002
    Link: http://cel-mar.pl/en/rs485rs422_rs48....htm?idk=1#poz
    Test results:
    Tested with: Modbus PI v3.7.5894.16328 (serial RTU master); Mastervolt XS2000 FW 4.00; Mastervolt ES 3.6 TL FW 3.01
    Functionality tested: read-out Input Registers; read-out Holding registers
    Limitations:
    - None (all functionality as described in the manual tested)
    Notes:
    - None
    KOICONTROL system
    Manufacturer: Koitronics
    Description: Monitoring of water values (pond)
    Device type: NA
    Model: NA
    Test results:
    Tested with: Modbus PI v3.7.5907.32639 (IP RTU master);
    Functionality tested: low alarms; high alarms; setting low- and high alarm setpoints; read-out values; reset alarm; general alarm
    Limitations:
    Notes:
    - None
    John
