Howto make the leds dance on my Crystal switch using the Stipus PLCbus connector.
dancing leds
Just follow the steps in the crystal switch documentation to enable the dancing led feature (if not already done).
Then, go to the PlcBus Connector plugin Web configuration interface, and create an Appliance Device P15. --> Device code must be P15.
Then each time you click P15 ON (HomeSeer status page), crystal switch leds start dancing. Press P15 ON again, and the dance pattern changes (there are a few dance patterns available).
Press P15 OFF, and leds stop dancing.--
stipus
I have been snooping the T4034E controller while holding P15 OFF, and pressing All Lights ON for 5 Secs.
This sends a Scene Address Programming for P15, with databyte set to 3.
Received: (255) P15 SceneAddressSetup Data1:3 Data2:0 Tx:False AckReq:False Ack:False IDreq:False Id:False 3PhReq:False RiscOK:True PlcBusOK:True
If you have 3 crystal switches C1, D1, E1 that you want to see dancing:
- Create a new PlcBus Scene Device P15
- Add a scene entry C1 OFF
- Add a scene entry D1 OFF
- Add a scene entry E1 OFF
- Program the scene
I can't test as I don't have any crystal switch anymore, but I think it should work.--
stipus
I have been using the PLCBUS 1141 interface, with the plugin in DebugMode.
I did press the keys on the PLCBUS 4034E controller in the order shown in the doc to enable dancing leds, and I watched the HomeSeer log.
I could see a Scene programming Plcbus command for P15 with databyte set to 3 (that's to set devices off).
Programming a scene with off devices from the plugin should send the exact same command.
However the plugin also sends other commands during scene programming... and this might interfere...
I'll see if I can add a plugin API to send any PlcBus command from a HS Script.--
stipus
Here is a new version with 2 new APIs:
hs.Plugin( "PLCBUS Connector" ).SendPlcBusByteCommand( byteArrayString as String )
the string parameter must be the array of bytes that are sent to the Plcbus 1141 interface. You have to know the Plcbus protocol to use this.
This sends A1 ON for usercode 100
hs.Plugin( "PLCBUS Connector" ).SendPlcBusByteCommand( "2,5,100,0,2,0,0,3" )
hs.Plugin( "PLCBUS Connector" ).SendPlcBusCommand( deviceCode as String, plcBusFunction as Integer, data1 as Integer, data2 as Integer, feedback as Boolean )
This one is easier to use.
hs.Plugin( "PLCBUS Connector" ).SendPlcBusCommand( "A1", 2, 0, 0, false )
The second argument (PlcBusFunction) must be one of:
AllUnitsOff = 0,
AllLightsOn = 1,
On = 2,
Off = 3,
Dim = 4,
Bright = 5,
AllLightsOff = 6,
AllUserLightsOn =7,
AllUserUnitsOff =8,
AllUserLightsOff = 9,
Blink = 10,
FadeStop = 11,
PresetDim = 12,
StatusOn = 13,
StatusOff = 14,
StatusRequest =15,
ReceiverMasterAddressSetup =16,
TransmitterMasterAddressSetup =17,
SceneAddressSetup =18,
SceneAddressErase =19,
AllSceneAddressErase = 20,
Reserved1 = 21,
Reserved2 = 22,
Reserved3 = 23,
GetSignalStrength = 24,
GetNoiseStrength = 25,
ReportSignalStrength = 26,
ReportNoiseStrength = 27,
GetAllIdPulse = 28,
GetOnlyOnIdPulse = 29,
ReportAllIdPulse3Phase = 30,
ReportOnlyOnIdPulse3Phase = 31
If I follow the documentation for the dancing function assuming switch is C1:
1) Switch on the light on this crystal switch
hs.Plugin( "PLCBUS Connector" ).SendPlcBusCommand( "C1", 2, 0, 0, false )
2) using the PLCBUS controller, press and hold P15 OFF. This sends P15 OFF
hs.Plugin( "PLCBUS Connector" ).SendPlcBusCommand( "P15", 3, 0, 0, false )
3) press and hold "All lights On" for about 5 seconds. This sends the scene address programming with databyte1 set to 3
hs.Plugin( "PLCBUS Connector" ).SendPlcBusCommand( "P15", 18, 3, 0, false )
PS: these commands work from a VB.NET script. You have to remove function parenthesis () after SendPlcBusCommand, if you try this from the HomeSeer immediate command window as it's not VB.NET
[EDIT] attachement removed as it's now available from the updater.Last edited by stipus; October 16, 2008, 12:24 PM.--
stipus
Change Status of P15 everytime you change dancemode.
Hi, this is only a idea to let the status message change to Dance1,Dance2,Dance3,Dance Ended so you can have different symbols for the dancing mode.
Setup a Trigger based on "Device Status Change" , "Set Any Status" and call this script.
I have notice that the value does not change in realtime on P15, mybe someone could update the script to fix this? If you refresh the page you se the right value.
PHP Code:Sub Main
str_debug = true
dim dancenumber
If hs.isoff("P15") = true Then
hs.setdevicestring "P15","Dance off"
hs.SetDeviceLastChange "P15",now
hs.SaveINISetting "Settings","plcbus",0,""
if str_debug = true then hs.writelog "Dance","Dance Ended" & dancenumber
exit sub
Else
dancenumber = hs.getINIsetting("Settings","plcbus",0,"")
if dancenumber > 2 then
hs.SaveINISetting "Settings","plcbus",1,""
dancenumber = 1
else
dancenumber = dancenumber + 1
hs.SaveINISetting "Settings","plcbus",dancenumber,""
End If
If str_debug = true then hs.writelog "Dance","No:" & dancenumber
hs.setdevicestring "P15","Dance" & dancenumber
End If
End Sub
Tasker Plugin / Speech Droid
Tonlof | Sweden
dancing leds feature removed in new Crystal Switches
There has been a change of design with PLC-Bus to Crystal Switches.
Because there could be some flickering issue's with the 3 IC's setup (white label) they now produce introduced a 1 IC (red label) wich should be more stable.
Also they removed the dancing led feature and the intensity indicator (center leds)... verry sad
and added a local push button to change (in 3 steps) the intensity of the leds.
See http://www.s10.cn/uu.htm for official statement.
