Hi Stipus, all
Today I upgraded from v1.23 to v1.30 but whenever I try to get to PCBUS Connector Configuration I get the following error below.
I've try to stop/start the service and have rebooted the computer.
How can I solve the problem?
Jan
Server Error in '/' Application.
Method not found: 'Int32 HSPI_PLCBUS.HSPI.get_FastPollingDelay()'.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.MissingMethodException: Method not found: 'Int32 HSPI_PLCBUS.HSPI.get_FastPollingDelay()'.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[MissingMethodException: Method not found: 'Int32 HSPI_PLCBUS.HSPI.get_FastPollingDelay()'.]
Settings.Page_Load(Object sender, EventArgs e) +0
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Obje ct sender, EventArgs e) +43
System.Web.UI.Control.OnLoad(EventArgs e) +73
System.Web.UI.Control.LoadRecursive() +52
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2184
Version Information: Microsoft .NET Framework Version:2.0.50727.3082; ASP.NET Version:2.0.50727.3082
Jan
Source Error:
Stack Trace:
