DESCRIPTION
This plug-in is designed to work with the Plugwise Stick, Plugwise Stretch gateway, Adam gateway, Anna thermostat and Smile P1 smart meter. There is no limit to the amount of devices and gateways it can support.
REQUIREMENTS
There are no additional software requirements. The plug-in can be installed from the HS3 updater, and can be found under the section “Lighting & Primary Technology”.
CONFIGURATION
Please consult the documentation: HomeSeer HS3 Plugwise Pro 4.0.pdf
TROUBLESHOOTING
If anything doesn’t work, you can try one the following:
NOTES
REQUIREMENTS
- This plugin is for HS3 or HS3PRO. It works with both Windows and Linux versions
- Windows: .NET Framework 4.5 or later
- Linux: mono 4.x or later
- Properly configured Plugwise devices
CONFIGURATION
TROUBLESHOOTING
- Ensure the devices are working correctly when using the dedicated Plugwise App, Plugwise Source program and/or web interface of the device(s).
- Check the HS3 eventlog for any errors or clues.
- If all fails, enable debug logging and log to file. Send me the log so I can investigate.
NOTES
- This plugin has been tested with the latest firmware on all relevant devices. Older versions might give unexpected results as they are untested.
- There is an almost unlimited combination possible of the Stick, gateway, and appliances. I tested as much as possible, but I am sure I missed some combinations. Let me know if something doesn't seem to work as expected.
- I do not own the Koen and Sting. So the probably do not work (correctly) and/or cause issues with the plugin. If you do own those devices and want to help me get them included in the plugin, let me know!
