Scenes Anna
    Scenes Anna
    How can I set the Anna scenes (home, away, sleep, vacation)?
    I can only find the settings by temperature, not the scenes:
    Jos
    If the Anna has any zones, they should show up automatically. I assume you can select presets from the Anna interface itself?
    What firmware are you running on the Anna?
    stefxx
      Thank you for your very fast reply.
      Earlier I used the IPThermostat plugin in which I could trigger the scenes. They are currently also available on my Anna and in the webinterface.
      The web interface of the Anna tells me I'm on firmware version 4.019.
      Thanks again!
        I can reproduce this with firmware 4.19. Let me look into this.
        stefxx
          Please try the latest HS3 Plugwise Pro beta (4.0.0.10), that should resolve it.
          Let me know if that works for you, so I can release it as a stable version (and update the HS4 version as well as that needs to reflect the same change)
          Thanks!!
          stefxx
            I've installed 4.0.0.10 and it seems to work fine. I've tested:
            Change preset in HS web browser
            Change scene in Anna web browser
            Change by events
            Thanks for the quick solution!
              Great. Thanks again.
              stefxx
