You are indeed correct. For some reason the .exe. is not copied to the HS3 directory. If you look in your HS3 directory in a subdirectory called Updates3 you should find HSPI_TasMQTT.exe which you can just copy into your HS3 directory and that'll fix it. I'll look at the problem now and sort the updater.
