Strips only use one IP address and the strip itself handles which plug to fire (on/off). Did you try uninstalling the strip then reinstalling? This could fix your problem.
TPLink Smarthome Plugin
This is a sticky topic.
Hi James,
there is a needs fixing true.
here it is:
Device Details
device_version : |19.3.23|19.4.4
error_count : 0
tplink_alias : Strip Plug 1
tplink_ip : 10.241.7.29
tplink_poll_priority : 3
tplink_power_change : false
pollPriority : 3
DevRef : 483
MacAddress : D807B62095ED
needsFixing : True
Alias : Strip Plug 1
HSAddress : D807B62095EDJV00
Hostname : 10.241.7.29
DeviceType : 0
OutletNum : 00
Model : unknown
Polling frequency: 20 sec1 min2 min
Get TPLink Detailsoutlets : System.Collections.Generic.List`1[HSPI_TPLinkSmartHome.Devices.TPLinkSmartPlug+child_outlet]
monthStat : GetPropValue(monthStat) not valid/found
dayStat : GetPropValue(dayStat) not valid/found
current : -1
voltage : -1
power : -1
total : -1
PoweredOn : True
LedOn : False
PoweredOnSince : 11/15/2020 8:34:55 PM
Features : TIM
NumberOfChildOutlets : 3
CurrentOutlet : 00
OnlineStatusChanged : False
isOnline : True
IsOn : True
Port : 9999
MessageCache : HSPI_TPLinkSmartHome.Messaging.TimeGatedMessageCache
SoftwareVersion : 1.0.4 Build 200828 Rel.165029
HardwareVersion : 1.0
Type : IOT.SMARTPLUGSWITCH
Model : KP303(UK)
MacAddress : D8:07:B6:20:95:ED
DevName : GetPropValue(DevName) not valid/found
HardwareId : 8A263122E4686102C1C8C805202C33CD
FirmwareId : n/a
DeviceId : 800698D27D86BBBBDB49B3FA744A9A791D1920F4
OemId : 707DC0D8FE3A745AAC776E000DC1CF15
RSSI : -58
LocationLatLong :
CurrentTime : 11/15/2020 9:23:10 PM
Failure to Connect Count : 0
Hi, the reinstall worked! Thanks.
However I have noticed another anomaly.
if the device name is changed in kasha (iOS management app) the device will pick up on the new name. However the status page will not.
deleting and re adding works. It looks like the device name in the status page is set on add and then not updated if it changes.
cheers!
[QUOTE=
cheers![/QUOTE]
That's because the plugin is using the MAC address of the Kasa device and not the name behind the scene. If you delete and re-add it will give it the new name as when you deleted it now the plugin doesn't know the MAC address anymore and will accept the changed (new) name
(Reposting here as I didn't get any response in separate thread. Appreciate any inputs)
HS3 plugin not finding devices after a power outage recovery
I recently installed this plugin to control a couple Kasa plugs via events. I had a momentary power outage today and when the homeseer started up this plugiin it said 'No devices found' in the log (presumably because the router itself is starting up at the same time). However I would have expected the plugin to poll and re-discover the devices. It didn't. So the automatic events that ran never actually accomplished their tasks via this plugin (to turn off the plugs). Has anyone else experienced this. I had to manually restart this plugin before it was able to discover the devices to control. Let me know if there is a way around it as the events are controlling some aquarium lighting/CO2 in my case and I can't let them run past the allotted time esp. when I am away. thanks
Date/time=12/27/2020 10:41:45 AM CST
Version=HS4 Pro Edition 4.1.8.0 (Linux)
MONO Version=Mono JIT compiler version 5.20.1.19 (tarball Thu Apr 11 09:14:25 UTC 2019)
License=Registered
Confguration File=/usr/local/HomeSeer/Data/HomeSeerData.json
Uptime=58 Days 1 Hour 59 Minutes 23 Seconds
Lan IP=127.0.0.1 (HomeTrollerSELv5)
Device Count=214
Event Count=14
Plugins Enabled=NetCAM:,weatherXML:,Rachio:,SmartThings:,BLLAN:,Z-Wave:,TPLinkSmartHome:
Modules/Threads=101 Modules, 58 Threads
Available Threads=199
HomeSeer Memory Used=125 Mbytes
Plugins Installed=BLLAN 2.0.45.0,NetCAM 3.0.0.14,Rachio 4.0.1.0,SmartThings 4.0.15.0,TPLinkSmartHome 19.10.7.1,weatherXML 3.0.1.19,Z-Wave 3.0.2.0
I've had power outages (I have a cabin in the local mountains where power is not always consistent) and the plugin did re-established connection to the tplink devices. I do think the plugin might not be able to reconnect if the IP addresses changed. I am focused on my last beta of the HS4 version of the plugin and I will test the power outage scenario. Oh yeah! It does take 10ish minutes for the HS3 plugin to recover so there is that window where events will not run.James
Running HS 3 on Win10 .
Thanks James. Just rebooting the router causes this issue for me. It did not re-establish connection for over 8 hours and I had to rediscover. I will test with static IPs for the plugs and report back. They are currently on DHCP.
Also, can I test your HS4 plugin on my Hometroller SEL or is it only available in Windows.
Originally posted by vrajkuma View PostThanks James. Just rebooting the router causes this issue for me. It did not re-establish connection for over 8 hours and I had to rediscover. I will test with static IPs for the plugs and report back. They are currently on DHCP.
Also, can I test your HS4 plugin on my Hometroller SEL or is it only available in Windows.James
