No Energy Devices?
    No Energy Devices?
    Hi,
    I have a HS110 Plug, which discovers all right with all methods (tried IP, Broadcast & Kasa), but doesn't create any energy related devices in HS. There's a master device called "TPLinkSmartHome Config" and another one for the plug itself with On/Off buttons and nothing else. On/Off works fine.
    The Casa-App on the phone shows the energy values.
    The device is discovered as
    SmartPlug Models: HS110(EU)
    SmartPlug Energi Models: HS110(EU)
    Any idea where to look?
    Cheers,
    Alex
    The setup screen has some checkboxes that tell the plugin what support devices to create. Do you have those checked? If not turn them on and the plugin will create the additional devices. Give it about 10 minutes since it checks for those type of changes at a longer interval.
    James
    Running HS 3 on Win10 .
      Hi James,
      Yes, the boxes were always checked. I believe they are that way by default. I've never touched them.
      I have about 900 devices in my HS, so sometimes devices kinda get lost, but I've looked into every corner - those energy devices aren't anywhere to be found. The plug has now been discovered for a couple hours. I've even contacted a battery charger to ramp up some kWh, but up to now nothing's happened.
      Cheers,
      Alex
        On the plugin status page, can you expand the arrow labeled "The following TPLink device models..." and send a snip of that section.
        Also, in the plugs device config there should be a "TPlinkSmartHome" tab. After you click on the "Get TPlink Details" can you tell me what it says on the "Features" field?
        Lastly, can you also send me a snip of the "TPLinkSmartHome" tab of the "TPLinkSmartHome Config" device.
        James
          Device/TPLinkSmartHome/TPLink Details/Features says "Features : TIM|ENE"
          Alex
            This is what I've got after discovery btw:
            Alex
              Just added a second plug of the same type, just to make sure the other one isn't broken in any way. Same thing - only the switch itself, no energy stuff. They are both on the latest firmware according to the KASA app.
              Alex
                It does look like a bug. Let me dig in tonight and get you a test version to figure this out. Thanks for bringing it up.
                James
                  I am missing the config snip for the devices. Click on the test1 device and then click the TPLinkSmartHome tab and click on the get the details . See attached.
                  James
                    Hi James,
                    The info you're looking for is actually at the top of my response:
                    And no hurry. You're providing this for free, so please take your time. I promise I won't ask for my money back ;-)
                    Alex
                      I see it now. Glad you read the refund policy. Haha.
                      James
                        Not sure if that makes any difference, but mine seem to be newer than yours. Here is the full device info:
                        Device Details
                        error_count : 0
                        tplink_alias : Test 1
                        tplink_ip : 192.168.123.150
                        tplink_model : HS110(EU)
                        tplink_poll_priority : 3
                        tplink_power_change : false
                        pollPriority : 3
                        DevRef : 2590
                        MacAddress : 98DAC45CED3F
                        needsFixing : False
                        Alias : Test 1
                        HSAddress : 98DAC45CED3F
                        Hostname : 192.168.123.150
                        DeviceType : 1
                        OutletNum : GetPropValue(OutletNum) not valid/found
                        Model : HS110(EU)
                        Polling frequency: 2 min
                        outlets : System.Collections.Generic.List`1[HSPI_TPLinkSmartHome.Devices.TPLinkSmartPlug+child_outlet]
                        monthStat : { "month_list": [ { "year": 2019, "month": 9, "energy_wh": 44 } ], "err_code": 0 }
                        dayStat : { "day_list": [ { "year": 2019, "month": 9, "day": 18, "energy_wh": 44 } ], "err_code": 0 }
                        current : 0,016
                        voltage : 228,142
                        power : 0,957
                        total : 0,044
                        PoweredOn : False
                        LedOn : False
                        PoweredOnSince : 01.01.0001 00:00:00
                        Features : TIM|ENE
                        NumberOfChildOutlets : 0
                        CurrentOutlet : 00
                        OnlineStatusChanged : False
                        isOnline : True
                        IsOn : True
                        Port : 9999
                        MessageCache : HSPI_TPLinkSmartHome.Messaging.TimeGatedMessageCache
                        SoftwareVersion : 1.5.4 Build 180815 Rel.121440
                        HardwareVersion : 2.0
                        Type : IOT.SMARTPLUGSWITCH
                        Model : HS110(EU)
                        MacAddress : 98:DA:C4:5C:ED:3F
                        DevName : Smart Wi-Fi Plug With Energy Monitoring
                        HardwareId : 044A516EE63C875F9458DA25C2CCC5A0
                        FirmwareId : 00000000000000000000000000000000
                        DeviceId : 8006A272613105A8FEF6A8CFF2E52ACC1BA55A96
                        OemId : 1998A14DAA86E4E001FD7CAF42868B5E
                        RSSI : -64
                        LocationLatLong : 494606|108853
                        Alias : Test 1
                        CurrentTime : 18.09.2019 23:50:23
                        Failure to Connect Count : 0
                          Just an update.. Still working on it and my "debug tracking code" isn't where I want it . Hopefully more progress today.
                          James
                            I now have a version posted in the beta part of this form (version 19.9.19) which will give me additional info. Please go to the setup page, click on debug and turn on the debug checkbox. After about an hour, please check your log and filter based on "TPLinkSmartHome Debug" and send me a snip it of the earliest ones. The entries will look like this.
                             [TABLE="class: log_table_row, cellspacing: 0"]
                            [TR]
                            [TD="class: LogDateLong LogDateTime1, colspan: 1, align: left"][COLOR=#000000]Sep-19 10:53:29 AM [/COLOR][/TD]
                             			[TD="class: LogPri1, colspan: 1, align: left"][COLOR=#000000]  [/COLOR][/TD]
                             			[TD="class: LogType1, colspan: 3, align: left"][COLOR=#000000]TPLinkSmartHome Debug [/COLOR][/TD]
                             			[TD="class: LogEntry1, colspan: 8, align: left"][COLOR=#000000]for pIP:192.168.12.145 device D80D1763EC67JV05-watts already exists [/COLOR][/TD]
                             		[/TR]
                            [/TABLE]
                            James
                              Hi James,
                              I've done that, but the result doesnt seem to be quite right. I've started the debug plugin and set debug at about 22:02 my time and this is what happens since then:
                              Sep-19 22:17:32 Starting Plug-In Plugin TPLinkSmartHome started successfully in 1332 milliseconds
                              Sep-19 22:17:32 TPLinkSmartHome Checking for devices owned by TPLinkSmartHome
                              Sep-19 22:17:31 Starting Plug-In Initializing plugin TPLinkSmartHome ...
                              Sep-19 22:17:31 Starting Plug-In TPLinkSmartHome loaded in 15050 milliseconds
                              Sep-19 22:17:16 Info Plugin TPLinkSmartHome has connected. IP:127.0.0.1:54912
                              Sep-19 22:17:16 Warning I/O interface TPLinkSmartHome is down, executable is not running, restarting ...
                              Sep-19 22:16:52 Info Plugin TPLinkSmartHome with instance: has disconnected
                              Sep-19 22:14:16 Starting Plug-In Plugin TPLinkSmartHome started successfully in 1243 milliseconds
                              Sep-19 22:14:16 TPLinkSmartHome Checking for devices owned by TPLinkSmartHome
                              Sep-19 22:14:15 Starting Plug-In Initializing plugin TPLinkSmartHome ...
                              Sep-19 22:14:15 Starting Plug-In TPLinkSmartHome loaded in 15046 milliseconds
                              Sep-19 22:14:00 Info Plugin TPLinkSmartHome has connected. IP:127.0.0.1:54871
                              Sep-19 22:14:00 Warning I/O interface TPLinkSmartHome is down, executable is not running, restarting ...
                              Sep-19 22:13:36 Info Plugin TPLinkSmartHome with instance: has disconnected
                              Sep-19 22:11:00 Starting Plug-In Plugin TPLinkSmartHome started successfully in 1150 milliseconds
                              Sep-19 22:11:00 TPLinkSmartHome Checking for devices owned by TPLinkSmartHome
                              Sep-19 22:10:59 Starting Plug-In Initializing plugin TPLinkSmartHome ...
                              Sep-19 22:10:59 Starting Plug-In TPLinkSmartHome loaded in 15048 milliseconds
                              Sep-19 22:10:44 Info Plugin TPLinkSmartHome has connected. IP:127.0.0.1:54838
                              Sep-19 22:10:44 Warning I/O interface TPLinkSmartHome is down, executable is not running, restarting ...
                              Sep-19 22:10:20 Info Plugin TPLinkSmartHome with instance: has disconnected
                              Sep-19 22:07:44 Starting Plug-In Plugin TPLinkSmartHome started successfully in 1202 milliseconds
                              Sep-19 22:07:44 TPLinkSmartHome Checking for devices owned by TPLinkSmartHome
                              Sep-19 22:07:43 Starting Plug-In Initializing plugin TPLinkSmartHome ...
                              Sep-19 22:07:42 Starting Plug-In TPLinkSmartHome loaded in 15048 milliseconds
                              Sep-19 22:07:27 Info Plugin TPLinkSmartHome has connected. IP:127.0.0.1:54802
                              Sep-19 22:07:27 Warning I/O interface TPLinkSmartHome is down, executable is not running, restarting ...
                              Sep-19 22:07:03 Info Plugin TPLinkSmartHome with instance: has disconnected
                              Sep-19 22:04:28 Starting Plug-In Plugin TPLinkSmartHome started successfully in 1128 milliseconds
                              Sep-19 22:04:28 TPLinkSmartHome Checking for devices owned by TPLinkSmartHome
                              Sep-19 22:04:26 Starting Plug-In Initializing plugin TPLinkSmartHome ...
                              Sep-19 22:04:26 Starting Plug-In TPLinkSmartHome loaded in 15051 milliseconds
                              Sep-19 22:04:11 Info Plugin TPLinkSmartHome has connected. IP:127.0.0.1:54765
                              Sep-19 22:04:11 Warning I/O interface TPLinkSmartHome is down, executable is not running, restarting ...
                              Seems like the plugin is crashing/restarting every 3 minutes. I've also tested the plugin with Debug off - still crashing/restarting.
                              Doesnt look right...
