Hi
I have a Power Strip model KP303(AU). It is working fine turning on and off my pool filter system according to a schedule.
I have a Push notification triggered every time it turns on and off.
I'm seeing that occasionally I get a notification the pool system has turned off when it should still be on. Two minutes later (after poll), I get another message it has turned on again.
When I check the device immediately following the notification, it is actually on and appears to have never to have turned off.
I thought this could have just been the power strip device. I setup the same notification trigger on a KP110 model and I'm having the same issue. I'm guessing something is causing an incorrect report of the power state which is then corrected on the next poll.
Any thoughts?
Any thoughts?
