How do you set the white color of a bulb while its running with out changing the brightness ?
I can see the option for when the bulb is off
turn on / brightness 1% / set white color / brightness 0% / turn off.
I'm trying to make a event that will change the white color of a bulb based on the weather and or time of day.
I like to use the fade duration so the change is not to noticeable.
