I'm trying out this plugin and I'm not quite sure how to use the Set White option. Here is how I've got it set up:
The other light turns on as it should but I can't get the LIFX Z to turn on using this method. The only way I've been able to turn on these lights (through Homeseer) has been with the "CONTROL A DEVICE" function. The problem with that is it just turns it on to what ever color the bulb was last set to.
All I want to do (for now) is make sure the light turns on to the appropriate temperature and brightness when the light is turned on using this method.
Thanks.
Thanks.
