Does the LIFX bulb and your HomeSeer system exist on the same IP network? Are any of the network switches in your home configured to block broadcast packets?
Well that seems to have fixed it. It didn't detect the bulb right away, but when I came back a few hours later it had detected it and seems to work as it should. Thanks!
New problem, I can't seem to change the color. When I go to the drop down to select the light it's not listed. It is however listed under the set white option.
