Help setting up this plugin
  • Help setting up this plugin
    I just has installed this plugin, it seems to initialize ok and shows it detected 2 lights, but the only devices I got are the 2 plugin devices: State (Enabled) and Root. I see no LIFX type devices in Homeseer, have I missed anything?
    Plug-In Status
    Status: OK
    Version: 3.0.6516.32486
    LIFX Lights
    Total Lights: 2
    LIFX Unknown: 0
    LIFX Original 1000: 0
    LIFX Color 650: 0
    LIFX White 800 (Low Voltage): 0
    LIFX White 800 (High Voltage): 0
    LIFX White 900 BR30 (Low Voltage): 0
    LIFX Color 1000 BR30: 0
    LIFX Color 1000: 0
    LIFX A19: 1
    LIFX BR30: 0
    LIFX + A19: 0
    LIFX + BR30: 0
    LIFX Z: 0
    LIFX Z 2: 1
    Plug-In Status
    Status: OK
    LIFX Lights
    Total Lights: 2
    LIFX Unknown: 0
    LIFX Color 650: 0
    LIFX Color 1000: 0
    LIFX A19: 1
    LIFX BR30: 0
    LIFX + A19: 0
    LIFX + BR30: 0
    LIFX Z: 0
    LIFX Z 2: 1
    This issue should been resolved. I am now pulling the LIFX Product JSON file from LIFX so any new bulbs will be properly detected (e.g. color vs whites).
    I'll post the update later today.
      Downloaded v. 3.0.6601.28887. The plugin found all my lights and identified correct types, but still see no devices.
        Plug-In Status
        Status: OK
        LIFX Lights
        Total Lights: 2
        LIFX Unknown: 0
        LIFX Color 650: 0
        LIFX Color 1000: 0
        LIFX A19: 1
        LIFX BR30: 0
        LIFX + A19: 0
        LIFX + BR30: 0
        LIFX Z: 0
        LIFX Z 2: 1
        Make sure the View > Devices > Floor and Room dropdowns are set to "Check All" so that all device would be displayed.
          Checked all, but I don't see type LIFX in device types
            From the Device Types drop down, you don't see anything starting with LIFX?
              No, there are no devices types with LIFX. I have attached the image of the device drop-down in my previous post.
                Is there any further advice to help with this plugin? I am unable to use it as there are no devices. I am not sure if this is of help, but I enabled debugging and here is what's in the log:
                3/3/2018 2:12:13 PM...Debug~~!~~Entered SelectPage() Function
                3/3/2018 2:12:13 PM...Debug~~!~~pageName=UltraLighting3
                3/3/2018 2:12:13 PM...Debug~~!~~Entered postBackProc() function.
                3/3/2018 2:12:13 PM...Debug~~!~~Entered Version() function.
                3/3/2018 2:12:15 PM...Debug~~!~~Device address 68213338895312 cannot be found.
                3/3/2018 2:12:16 PM...Debug~~!~~Device address 177979750970320 cannot be found.
                I am running
                3.0.6601.28887: UltraLighting3
                HomeSeer Version: HS3 Pro Edition 3.0.0.368
                Operating System: Microsoft Windows 7 Professional - Work Station
                  I am running
                  I dug into this and found where the plug-in won't create a device unless all of the values are discovered from the device itself. Can you confirm you have the latest firmware applied to your LIFX bulbs and each bulb has a name, location and group defined in the LIFX App?
                  Ultrajones
                    Thanks, that did it! After I had configured room and location on each device they have appeared in HS.
