configuration page
  • configuration page
    How do I make the configuration page appear?
    Usually there is a menu item in the Plug Ins menu that lets you open the config pages, but perhaps you are running into the same problem i am? (i don't have a solution yet)
    https://forums.homeseer.com/forum/li...pi-list-urgent
      please see link from mda for posible solution (i had same problem)
        I do not have this plug-in, but you could try entering
        http://<your HS3 IP address with port>/hspi_ultralighting3/hspi_ultralighting3.aspx
        in the address bar of your browser to see if you can access the config page.
        HS3 Pro Edition 3.0.0.548
          Uncle Michael Overst Wont work, the problem is that the plugin is not working properly.
          Becouse of this the config page also does not work.
          please see https://forums.homeseer.com/forum/li...pi-list-urgent
            Ok I got it to work. You must exit plugin. then delete. The remove all references to ultra lighting in data subdirectory, config subdirectory, and main hs3 folder. The reinstall the plugin.
