PI Listed in Manage but not under Plug-Ins
  • PI Listed in Manage but not under Plug-Ins
    Under Plug-Ins Manage I can see UltraLighting3 as loaded, status OK, there are no errors in log, latest version is loaded. But when I select just Plug-Ins it is not listed with all the other PI's and I cannot access it to check if a bulb has been recognized.
    What would cause this to not show as a loaded PI? I have rebooted the computer, deleted and re-installed the PI. thanks
    SOLVED. Had to delete PI and all it's files and sub-dirs and re-install. It is now back in the drop down and all lights controllable. bizarre.
      Thanks for posting - had the same problem, your fix worked.
        cowinger, any chance you can explain how I would go about deleting all the files and sub-directories? I'm running linux software on a Zee S2 controller. I would appreciate any help you can give.
