Plugin just stopped working, not available in the plug-ins menu
  • Plugin just stopped working, not available in the plug-ins menu
    Not sure what to do here but the UltraLighting3 plug-in no longer is able to control my LIFX lights as it appears to be broken.
    When I first went to the plugin menu and selected UltraLighting3, it went to a "404 Bad Request: /UltraLighting3" page.
    I've tried disable/enable and even delete & reinstall and it doesn't seem to give me a menu option any more.
    The logs don't have any errors in them for this issue - they have the standard setup stuff:
    May-19 10:51:07 PM Starting Plug-In Plugin UltraLighting3 started successfully in 551 milliseconds
    May-19 10:51:06 PM Starting Plug-In Initializing plugin UltraLighting3 ...
    May-19 10:51:06 PM Info Plugin UltraLighting3 has connected. IP:127.0.0.1:60243
    May-19 10:51:06 PM Plug-In Finished initializing plug-in UltraLighting3
    May-19 10:50:05 PM Updater Install/Update of package UltraLighting3 (LIFX LED WiFi Bulbs) was successful.
    May-19 10:50:05 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\hspi_ultralighting3\UltraLighting3_HSPI_Users_Guide .pdf
    May-19 10:50:05 PM Updater Extraction Complete.
    May-19 10:50:05 PM Updater Extracting files from zip file: images.zip
    May-19 10:50:05 PM Updater Extracting files from zip file: datatable-images.zip
    May-19 10:50:05 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\hspi_ultralighting3\css\jquery.dataTables.min.css
    May-19 10:50:05 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\hspi_ultralighting3\js\hspi_ultralighting3_devices. js
    May-19 10:50:05 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\hspi_ultralighting3\js\jquery.dataTables.min.js
    May-19 10:50:05 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_ULTRALIGHTING3.exe.config
    May-19 10:50:05 PM Updater Installing package UltraLighting3 (LIFX LED WiFi Bulbs)
    May-19 10:50:05 PM Updater Update hspi_ultralighting3.exe downloaded successfully
    May-19 10:50:04 PM Updater Downloading update: UltraLighting3 (LIFX LED WiFi Bulbs)
    May-19 10:50:04 PM Updater Starting download of updates
    Anyway, the plugin in the list shows it's running but the name is not an HTML link, and it doesn't appear in the list pulldown of the plugin menu (even after refreshing).
    Any thoughts?
    BTW, also tried upgrading it. It's now version 3.0.7027.33300
      UltraJones has some personal items he's been attending to and it's unknown as to when he'll be back.
        This is still an issue? Can I get a refund for this non-working plugin?
        Nobody else has this issue? It doesn't work at all for me now and I didn't do anything to break it.
        I'll look around for an alternative plug in to control LIFX items.
          The last time I did ask homeseer for s refund. I’ve been told I jad 30 days to test the plugin before purchase . So I do not think a refund is possible.
          But you can try , and see if that have changed
            I have the same version 3.0.7027.33300, and it's working for me. Occasionally I get a group of errors but they usually disappear themselves.
            Mike
              @dmcentire UltraLighting3 used to work for me but recently stopped working in the last month or so. I tried uninstalling and re-installing but that did not fix it. I also no longer see a config item for UltraLighting3 in the plugin drop down. UltraJones please fix!
                mwaite -- can you provide the URL you get when you mouse over the UltraLighting3 plugin in your plugin list?
                Just the suffix, you can exclude your server's hostname/IP. I'd like to see if I can get to it on my system.
                Mine is just black text, not a hyperlink, so I can't even try opening the plugin's config page.
                  There is no link on mine either (also black). If helpful, when I navigate to Plug-ins -> UltraLighting3 -> UltraLighting3 it takes me to {myIPaddr}/UltraLighting3:
                  Mike
                    Thanks for the info. I guess mine's just broken then for now.
                      Ultrajones
                      Ok... now I've been stricken with the same exact problem. Has been working solidly for a year or two and now suddenly.... poof! Nothing. All devices show offline and there is no config page available from the plug-ins drop down.
                      I even restored a full Homeseer backup from four months ago and exact same problem.
                      Any assistance to help me begin to diagnose the problem? No changes to computer it has been running on.
                      ​​​​​​​Paul
                        Maybe one of us can figure this out since the developer is MIA
                        The full restore not fixing it sounds frustrating -- I didn't try that but thought it would help. I guess not.
                        The common factor is that we seem to be running this on a computer where nothing changes. I don't even have Windows 10 Home updates enabled since the computer isn't reachable from the external network.
                          I am sorry, I have been MIA. I have been dealing with a few personal issues.
                          Please try the following:
                          Locate the file LIFX-Products.json in the HomeSeer HS3\Data\ultralighting3 directory and delete it, then restart the plug-in.
                          If that doesn't work, please post the LIFX-Products.json file here so I can try it on my own system to see if that's the issue.
                          Ultrajones
                            Ultrajones
                            Hey Ultrajones ,
                            Sorry to hear about your personal issues. I'm hopeful everything is resolving positively for you.
                            Deleting the .json file did solve the issue of the plug-in config page not showing up. However, I cannot control any of the bulbs.
                            I even tried creating new events but no joy.
                            I'm not sure if this is relevant for trouble shooting, but all the bulbs show OFFLINE when I look at the devices in Homeseer.
                            Thanks!
                            Paul
                            *EDIT - I turned on debug and ran an event. As you can see, it is just not seeing the lights. They do, however, work just fine using the app on my LAN so they are operational.
                            6/22/2019 3:44:59 PM...HomeSeerV~~!~~3.0.0.478
                            6/22/2019 3:44:59 PM...HomeSeerL~~!~~True
                            6/22/2019 3:44:59 PM...HomeSeerU~~!~~0 Days 5 Hours 42 Minutes 17 Seconds
                            6/22/2019 3:44:59 PM...Debug~~!~~Entered InitIO() Function.
                            6/22/2019 3:44:59 PM...Debug~~!~~Entered Version() function.
                            6/22/2019 3:44:59 PM...Informational~~!~~UltraLighting3 version 3.0.7027.33300 initializing...
                            6/22/2019 3:53:21 PM...Debug~~!~~Entered SelectPage() Function
                            6/22/2019 3:53:21 PM...Debug~~!~~pageName=UltraLighting3
                            6/22/2019 3:53:21 PM...Debug~~!~~Entered postBackProc() function.
                            6/22/2019 3:53:24 PM...Debug~~!~~Entered SelectPage() Function
                            6/22/2019 3:53:24 PM...Debug~~!~~pageName=UltraLighting3
                            6/22/2019 3:53:24 PM...Debug~~!~~Entered postBackProc() function.
                            6/22/2019 3:53:27 PM...Debug~~!~~Entered SelectPage() Function
                            6/22/2019 3:53:27 PM...Debug~~!~~pageName=UltraLighting3
                            6/22/2019 3:53:27 PM...Debug~~!~~Entered postBackProc() function.
                            6/22/2019 3:53:27 PM...Debug~~!~~Entered Version() function.
                            6/22/2019 3:53:46 PM...Debug~~!~~Waiting for LIFX target 57918201623504 to respond to command 102 with '6527' for up to 2.5 seconds ...
                            6/22/2019 3:53:46 PM...Debug~~!~~Waiting for LIFX target 131701444801488 to respond to command 102 with '22919' for up to 2.5 seconds ...
                            6/22/2019 3:53:46 PM...Debug~~!~~Waiting for LIFX target 148202709152720 to respond to command 102 with '23990' for up to 2.5 seconds ...
                            6/22/2019 3:53:46 PM...Debug~~!~~Waiting for LIFX target 34441910383568 to respond to command 102 with '29383' for up to 2.5 seconds ...
                            6/22/2019 3:53:46 PM...Debug~~!~~Waiting for LIFX target 201593447609296 to respond to command 102 with '27618' for up to 2.5 seconds ...
                            6/22/2019 3:53:46 PM...Debug~~!~~Waiting for LIFX target 112923847783376 to respond to command 102 with '8465' for up to 2.5 seconds ...
                            6/22/2019 3:53:46 PM...Debug~~!~~Waiting for LIFX target 252110852944848 to respond to command 102 with '31397' for up to 2.5 seconds ...
                            6/22/2019 3:53:48 PM...Debug~~!~~The LIFX target 114023359411152 failed to respond during attempt 1 of 2 to command 102
                            6/22/2019 3:53:48 PM...Debug~~!~~The LIFX target 148202709152720 failed to respond during attempt 1 of 2 to command 102
                            6/22/2019 3:53:48 PM...Debug~~!~~The LIFX target 34441910383568 failed to respond during attempt 1 of 2 to command 102
                            6/22/2019 3:53:48 PM...Debug~~!~~The LIFX target 57918201623504 failed to respond during attempt 1 of 2 to command 102
                            6/22/2019 3:53:48 PM...Debug~~!~~The LIFX target 201593447609296 failed to respond during attempt 1 of 2 to command 102
                            6/22/2019 3:53:48 PM...Debug~~!~~Waiting for LIFX target 112923847783376 to respond to command 102 with '8465' for up to 2.5 seconds ...
                            6/22/2019 3:53:48 PM...Debug~~!~~Waiting for LIFX target 252110852944848 to respond to command 102 with '31397' for up to 2.5 seconds ...
                            6/22/2019 3:53:48 PM...Debug~~!~~Waiting for LIFX target 148202709152720 to respond to command 102 with '23990' for up to 2.5 seconds ...
                            6/22/2019 3:53:48 PM...Debug~~!~~Waiting for LIFX target 114023359411152 to respond to command 102 with '2049' for up to 2.5 seconds ...
                            6/22/2019 3:53:48 PM...Debug~~!~~Waiting for LIFX target 34441910383568 to respond to command 102 with '29383' for up to 2.5 seconds ...
                            6/22/2019 3:53:48 PM...Debug~~!~~Waiting for LIFX target 57918201623504 to respond to command 102 with '6527' for up to 2.5 seconds ...
                            6/22/2019 3:53:48 PM...Debug~~!~~Waiting for LIFX target 201593447609296 to respond to command 102 with '27618' for up to 2.5 seconds ...
                            6/22/2019 3:53:51 PM...Debug~~!~~The LIFX target 34441910383568 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:51 PM...Debug~~!~~The LIFX target 114023359411152 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:51 PM...Debug~~!~~The LIFX target 148202709152720 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:51 PM...Debug~~!~~The LIFX target 112923847783376 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:51 PM...Debug~~!~~The LIFX target 131701444801488 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:51 PM...Debug~~!~~The LIFX target 57918201623504 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:51 PM...Debug~~!~~The LIFX target 201593447609296 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:51 PM...Debug~~!~~Waiting for LIFX target 112923847783376 to respond to command 102 with '10644' for up to 2.5 seconds ...
                            6/22/2019 3:53:51 PM...Debug~~!~~Waiting for LIFX target 57918201623504 to respond to command 102 with '29618' for up to 2.5 seconds ...
                            6/22/2019 3:53:51 PM...Debug~~!~~Waiting for LIFX target 252110852944848 to respond to command 102 with '22581' for up to 2.5 seconds ...
                            6/22/2019 3:53:51 PM...Debug~~!~~Waiting for LIFX target 114023359411152 to respond to command 102 with '4404' for up to 2.5 seconds ...
                            6/22/2019 3:53:51 PM...Debug~~!~~Waiting for LIFX target 34441910383568 to respond to command 102 with '28707' for up to 2.5 seconds ...
                            6/22/2019 3:53:51 PM...Debug~~!~~Waiting for LIFX target 201593447609296 to respond to command 102 with '24124' for up to 2.5 seconds ...
                            6/22/2019 3:53:51 PM...Debug~~!~~Waiting for LIFX target 131701444801488 to respond to command 102 with '26402' for up to 2.5 seconds ...
                            6/22/2019 3:53:51 PM...Debug~~!~~Waiting for LIFX target 148202709152720 to respond to command 102 with '25314' for up to 2.5 seconds ...
                            6/22/2019 3:53:54 PM...Debug~~!~~The LIFX target 112923847783376 failed to respond during attempt 1 of 2 to command 102
                            6/22/2019 3:53:54 PM...Debug~~!~~The LIFX target 252110852944848 failed to respond during attempt 1 of 2 to command 102
                            6/22/2019 3:53:54 PM...Debug~~!~~The LIFX target 34441910383568 failed to respond during attempt 1 of 2 to command 102
                            6/22/2019 3:53:54 PM...Debug~~!~~The LIFX target 114023359411152 failed to respond during attempt 1 of 2 to command 102
                            6/22/2019 3:53:54 PM...Debug~~!~~The LIFX target 201593447609296 failed to respond during attempt 1 of 2 to command 102
                            6/22/2019 3:53:54 PM...Debug~~!~~The LIFX target 131701444801488 failed to respond during attempt 1 of 2 to command 102
                            6/22/2019 3:53:54 PM...Debug~~!~~The LIFX target 148202709152720 failed to respond during attempt 1 of 2 to command 102
                            6/22/2019 3:53:54 PM...Debug~~!~~Waiting for LIFX target 112923847783376 to respond to command 102 with '10644' for up to 2.5 seconds ...
                            6/22/2019 3:53:54 PM...Debug~~!~~Waiting for LIFX target 252110852944848 to respond to command 102 with '22581' for up to 2.5 seconds ...
                            6/22/2019 3:53:54 PM...Debug~~!~~Waiting for LIFX target 34441910383568 to respond to command 102 with '28707' for up to 2.5 seconds ...
                            6/22/2019 3:53:54 PM...Debug~~!~~Waiting for LIFX target 57918201623504 to respond to command 102 with '29618' for up to 2.5 seconds ...
                            6/22/2019 3:53:54 PM...Debug~~!~~Waiting for LIFX target 114023359411152 to respond to command 102 with '4404' for up to 2.5 seconds ...
                            6/22/2019 3:53:54 PM...Debug~~!~~Waiting for LIFX target 201593447609296 to respond to command 102 with '24124' for up to 2.5 seconds ...
                            6/22/2019 3:53:54 PM...Debug~~!~~Waiting for LIFX target 131701444801488 to respond to command 102 with '26402' for up to 2.5 seconds ...
                            6/22/2019 3:53:54 PM...Debug~~!~~Waiting for LIFX target 148202709152720 to respond to command 102 with '25314' for up to 2.5 seconds ...
                            6/22/2019 3:53:56 PM...Debug~~!~~The LIFX target 252110852944848 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:56 PM...Debug~~!~~The LIFX target 201593447609296 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:56 PM...Debug~~!~~The LIFX target 34441910383568 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:56 PM...Debug~~!~~The LIFX target 57918201623504 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:56 PM...Debug~~!~~The LIFX target 131701444801488 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:56 PM...Debug~~!~~The LIFX target 148202709152720 failed to respond during attempt 2 of 2 to command 102
                            6/22/2019 3:53:56 PM...Debug~~!~~Waiting for LIFX target 112923847783376 to respond to command 117 with '28754' for up to 2.5 seconds ...
                            6/22/2019 3:53:56 PM...Debug~~!~~Waiting for LIFX target 252110852944848 to respond to command 117 with '10623' for up to 2.5 seconds ...
                            6/22/2019 3:53:56 PM...Debug~~!~~Waiting for LIFX target 201593447609296 to respond to command 117 with '27294' for up to 2.5 seconds ...
                            6/22/2019 3:53:56 PM...Debug~~!~~Waiting for LIFX target 114023359411152 to respond to command 117 with '21951' for up to 2.5 seconds ...
                            6/22/2019 3:53:57 PM...Debug~~!~~Waiting for LIFX target 131701444801488 to respond to command 117 with '24405' for up to 2.5 seconds ...
                            6/22/2019 3:53:57 PM...Debug~~!~~Waiting for LIFX target 148202709152720 to respond to command 117 with '24504' for up to 2.5 seconds ...
                            6/22/2019 3:53:59 PM...Debug~~!~~The LIFX target 252110852944848 failed to respond during attempt 1 of 2 to command 117
                            6/22/2019 3:53:59 PM...Debug~~!~~The LIFX target 112923847783376 failed to respond during attempt 1 of 2 to command 117
                            6/22/2019 3:53:59 PM...Debug~~!~~The LIFX target 201593447609296 failed to respond during attempt 1 of 2 to command 117
                            6/22/2019 3:53:59 PM...Debug~~!~~The LIFX target 34441910383568 failed to respond during attempt 1 of 2 to command 117
                            6/22/2019 3:53:59 PM...Debug~~!~~The LIFX target 114023359411152 failed to respond during attempt 1 of 2 to command 117
                            6/22/2019 3:53:59 PM...Debug~~!~~The LIFX target 57918201623504 failed to respond during attempt 1 of 2 to command 117
                            6/22/2019 3:53:59 PM...Debug~~!~~The LIFX target 148202709152720 failed to respond during attempt 1 of 2 to command 117
                            6/22/2019 3:53:59 PM...Debug~~!~~The LIFX target 131701444801488 failed to respond during attempt 1 of 2 to command 117
                            6/22/2019 3:53:59 PM...Debug~~!~~Waiting for LIFX target 112923847783376 to respond to command 117 with '28754' for up to 2.5 seconds ...
                            6/22/2019 3:53:59 PM...Debug~~!~~Waiting for LIFX target 252110852944848 to respond to command 117 with '10623' for up to 2.5 seconds ...
                            6/22/2019 3:53:59 PM...Debug~~!~~Waiting for LIFX target 201593447609296 to respond to command 117 with '27294' for up to 2.5 seconds ...
                            6/22/2019 3:53:59 PM...Debug~~!~~Waiting for LIFX target 114023359411152 to respond to command 117 with '21951' for up to 2.5 seconds ...
                            6/22/2019 3:53:59 PM...Debug~~!~~Waiting for LIFX target 34441910383568 to respond to command 117 with '13370' for up to 2.5 seconds ...
                            6/22/2019 3:53:59 PM...Debug~~!~~Waiting for LIFX target 57918201623504 to respond to command 117 with '19024' for up to 2.5 seconds ...
                            6/22/2019 3:53:59 PM...Debug~~!~~Waiting for LIFX target 148202709152720 to respond to command 117 with '24504' for up to 2.5 seconds ...
                            6/22/2019 3:53:59 PM...Debug~~!~~Waiting for LIFX target 131701444801488 to respond to command 117 with '24405' for up to 2.5 seconds ...
                            6/22/2019 3:54:02 PM...Debug~~!~~The LIFX target 112923847783376 failed to respond during attempt 2 of 2 to command 117
                            6/22/2019 3:54:02 PM...Debug~~!~~The LIFX target 252110852944848 failed to respond during attempt 2 of 2 to command 117
                            6/22/2019 3:54:02 PM...Debug~~!~~The LIFX target 34441910383568 failed to respond during attempt 2 of 2 to command 117
                            6/22/2019 3:54:02 PM...Debug~~!~~The LIFX target 201593447609296 failed to respond during attempt 2 of 2 to command 117
                            6/22/2019 3:54:02 PM...Debug~~!~~The LIFX target 57918201623504 failed to respond during attempt 2 of 2 to command 117
                            6/22/2019 3:54:02 PM...Debug~~!~~The LIFX target 148202709152720 failed to respond during attempt 2 of 2 to command 117
                            6/22/2019 3:54:02 PM...Debug~~!~~The LIFX target 131701444801488 failed to respond during attempt 2 of 2 to command 117
                              Originally posted by Wazoo View Post
                              Hey Ultrajones ,
                              Thanks!
                              Paul
                              The logs indicate responses to the UDP packets are not returning. Please check your router to make sure you're not suppressing UDP broadcast packets. Also check your HomeSeer system's firewall to make sure you're not blocking those UDP replies.
                              Ultrajones
