I installed the UltraLighting3 Plugin and I'm not getting the plugin to discover any of my bulbs at all. I tried to disable the firewall on my windows server that is running HS3 and no luck there. My HS3 instance is hardwired to my router and not wireless. I have one network in my environment and my LIFX bulbs (Total of 5) work fine via the app and also with my Amazon Echo, so they are performing properly. Any ideas?
Here is the info from the log. I disabled and then re-enabled to plugin to show you what comes up when I start it as well as screen shots from the plugin. I am still in the trial now and would like to buy this plugin if it works for my bulbs.
Thanks in advance!
Stephen
Thanks in advance!
Stephen
Jan-04 4:46:56 AM | Starting Plug-In | Plugin UltraLighting3 started successfully in 803 milliseconds |
Jan-04 4:46:55 AM | Starting Plug-In | Initializing plugin UltraLighting3 ... |
Jan-04 4:46:55 AM | Info | Plugin UltraLighting3 has connected. IP:127.0.0.1:54986 |
Jan-04 4:46:55 AM | Plug-In | Finished initializing plug-in UltraLighting3 |
Jan-04 4:46:55 AM | Plug-In | Interface UltraLighting3 is running as a trial, 12 days remaining. |
Jan-04 4:46:40 AM | Info | Plugin UltraLighting3 with instance: has disconnected |
Jan-04 4:46:40 AM | Plug-In | Shutting down Plug-In: UltraLighting3 |
