I was trying to get this to run on linux, but I'm having the following error, and the plugin won't load:
In the log I see:
To me, it looks like system.data.sqlite is not appropriately configured for distribution with mono on linux. Some things I found on google that may be helpful (maybe, maybe not). But nothing I can seem to fix on my end...
http://blog.wezeku.com/2016/10/09/us...inux-and-mono/
Any chance the developer can fix this for linux users please?
UltraLighting3
WARNING: Failed getting InterfaceStatus from UltraLighting3 - the interface was not found in the list of active interfaces, the list may need to be refreshed.
3.0.7272.26248
Registered
UltraLighting3 HSPI starting... Connecting to HomeSeer server at 127.0.0.1, attempt 1... 03:39:57:7867:[Info]->Plugin UltraLighting3 has connected. IP:127.0.0.1:60320 Connection to HomeSeer at 127.0.0.1, attempt 1 succeeded. 03:39:57:7891:[Starting Plug-In]->Initializing plugin UltraLighting3 ... 03:39:57:7941:[Error]->Initializing plug-in(2): UltraLighting3 Instance::Could not load type of field 'HSPI_ULTRALIGHTING3.Database:DBConnectionMain' (0) due to: Could not load file or assembly 'System.Data.SQLite, Version=1.0.87.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139' or one of its dependencies.STACK: Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x0014d] in <a1ae6166591d4020b810288d19af38d4>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,intptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.InitIO(string) at Scheduler.PluginHolder.InitIO (System.String PortNumber) [0x0000b] in <0416923db4e945eea4375ac293b623c6>:0 at Scheduler.clsHSPI.CheckInterfaces () [0x000bf] in <0416923db4e945eea4375ac293b623c6>:0 03:39:57:8379:[Starting Plug-In]->UltraLighting3 loaded in 200 milliseconds 03:39:57:8381:[Plug-In]->Finished initializing plug-in UltraLighting3
