After updating to the latest HS4 4.1.11.0 today (02/08/2021) all my LIFX bulbs appear as offline in UltraLighting. They were working fine prior to this. I tried stopping and restarting the plug-in and doing a full reboot of the system. All bulbs are on their latest firmware. They do work using the LIFX app.
All Bulbs Offline after HS4 4.1.11.0 Update
Are you running your HomeSeer system on Windows or Linux? If Windows, please connect to the console and check to see if you see a Windows firewall prompt asking for permission to listen on a UDP port.
Regards,
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Originally posted by Ultrajones View PostAre you running your HomeSeer system on Windows or Linux? If Windows, please connect to the console and check to see if you see a Windows firewall prompt asking for permission to listen on a UDP port.
Regards,
Ultrajones
Thanks.HS3Pro & HS4Pro on Win2012R2
Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-Wave
I am consistently having this issue, I updated the plugin recently as well and still having problems. I notice it seems to happen when HS4 or the box itself is rebooted, I'll go to the plugins tab and UltraLighting3 is listed as "Plugin start pending" - yet the plugin works, so is definitely running already, and can see the .exe in task manager.. About 50% of my lights will be "offline" when this happens usually though, disabling the plugin and then restarting it seems to bring my lights all back online.
I was scratching my head trying to figure out how to create an Event that would restart the plugin "If XXX light has been Offline for exactly XXX" but could not figure out how to create an event action that did this, that probably would solve the problem if anyone had any tips on that.
Otherwise, is there any tweaks that can be made to the plugin to correct this? My issue is that my controller will occasionally be rebooted without my knowledge - power loss, automatic update, who knows what - I have HS4 setup to restart automatically, but when my lights don't reconnect it screws up other events which then don't fire properly.
I'd like to express my willingness to re-purchase a newer version of this plugin that has been reengineered for HS4 specifically. Thanks!
Originally posted by ee21 View PostI am consistently having this issue, I updated the plugin recently as well and still having problems. I notice it seems to happen when HS4 or the box itself is rebooted, I'll go to the plugins tab and UltraLighting3 is listed as "Plugin start pending" - yet the plugin works, so is definitely running already, and can see the .exe in task manager.. About 50% of my lights will be "offline" when this happens usually though, disabling the plugin and then restarting it seems to bring my lights all back online.
I have never been able to figure out why the older LIFX bulbs stop responding to the UDP status query. About a year and a half ago, a firmware update was pushed by LFIX which fixed this issue for the LIFX Color 1000 bulbs. They were on track to push a similar firmware update for the older bulbs, but then COVID hit.Plug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
