UltraLighting3 Beta
  • I just installed version 3.0.6516.32486. Do I need the Beta??
    It found the one (1) single LIFX Light I have and its an LHA19E26UC10.
    It is a full color light, yet HS / the plugin is only showing it as a white bulb with no way to change the color.
    It come up as an LIFX A19.
    The plugin page for the device shows what you see below and the main
    Group: Living Room
    Device Name: Living Room Reading
    Device Id: 49873778209744
    Product Name: LIFX A19
    Product Version: 0
    Host Firmware: 2.69
    IP Address: 192.168.1.197
    MAC Address: (if you need it let me know)
    Service Type: 5
    Service Port: 56700
    Service State: 1
    WiFi Version: 0
    WiFi Signal: 50
    WiFi Rx: (if you need it let me know)
    WiFi Tx: (if you need it let me know)
    Powered On Time: 12/31/2017 7:03:31 PM
    Last Send Event: 1/1/2018 7:18:11 PM
    Last Receive Event: 1/1/2018 7:18:11 PM
    • Originally posted by rjbur View Post
      Group: Living Room
      Product Version: 0
      Host Firmware: 2.69
      Service Type: 5
      Service Port: 56700
      Service State: 1
      WiFi Version: 0
      WiFi Signal: 50
      If your bulb supports color, then the only means of changing the color is through a HomeSeer event. Are you saying the options for the bulbs within the event do not allow you to change the color?
      Ultrajones
      • Originally posted by bojack View Post
        Sure!
        Plug-In Status
        Status: OK
        Version: 3.0.6516.32486
        LIFX Lights
        Total Lights: 1
        LIFX Unknown: 0
        LIFX Original 1000: 0
        LIFX Color 650: 0
        LIFX White 800 (Low Voltage): 0
        LIFX White 800 (High Voltage): 0
        LIFX White 900 BR30 (Low Voltage): 0
        LIFX Color 1000 BR30: 0
        LIFX Color 1000: 0
        LIFX A19: 0
        LIFX BR30: 0
        LIFX + A19: 0
        LIFX + BR30: 0
        LIFX Z: 0
        LIFX Z 2: 1
        LIFX Downlight: 0
        LIFX Downlignt: 0
        LIFX A19: 0
        LIFX BR30: 0
        LIFX + A19: 0
        LIFX + BR30: 0
        LIFX Mini: 0
        LIFX Mini White: 0
        LIFX Mini Day and Dusk: 0
        LIFX GU10: 0
        LIFX Network Status
        Commands In Queue: 0
        Last Send Event: 12/30/2017 7:59:41 AM
        Last Receive Event: 12/30/2017 7:59:41 AM
        Color changes for LIFX bulbs are currently done through HomeSeer events. Have you attempted to create an event to change the color or is the color option for the bulb you have not available?
        • Yup, but no luck. The event actions that work are Set White, Set Power, and Set Brightness. If I select Set Color or Set Waveform then my light doesn't show up under the LIFX Lights pulldown menu.
          • Originally posted by Ultrajones View Post
            Ultrajones
            Yes, the LIFX A19 color bulb is not showing up with any Color control as the Hue lights do on my Home or View Devices page. Even in an Event all I can to is change intensity 0-99%, On, Off, On Last Level.
              What version of the UltraLighting3 HSPI are you running?
              Sorry it has taken so long to respond. The version is 3.0.6516.32486.
              I got a First Alert smoke alarm and was trying to set the bulbs to flash red when it goes off. I can’t see the Minis under the waveform event either.
              Bulb model
              https://www.dropbox.com/s/nrpapipxe9..._9912.PNG?dl=0
              Color wheel
              https://www.dropbox.com/s/wiuf3a71wb..._9913.PNG?dl=0
              • I just received some new bulbs and I was able to duplicate the issues related to not being able to control the color via an event. I'll working on getting an update posted within the next day.
                Ultrajones
                • No devices?
                  I just has installed this plugin, it seems to initialize ok and shows it detected 2 lights, but the only devices I got are the 2 plugin devices: State (Enabled) and Root. I see no LIFX type devices in Homeseer, have I missed anything?
                  Plug-In Status
                  Status: OK
                  LIFX Lights
                  Total Lights: 2
                  LIFX Unknown: 0
                  LIFX Color 650: 0
                  LIFX Color 1000: 0
                  LIFX A19: 1
                  LIFX BR30: 0
                  LIFX + A19: 0
                  LIFX + BR30: 0
                  LIFX Z: 0
                  LIFX Z 2: 1
                  • Wondering if there was any update available yet? Not sure if I've missed it or not 😀 Fantastic plugin too, works seamlessly for me.
