consider this scenario:
a)
Now scenario b - which works fine
b)
Right now I've got an event for the morning, that basically sets the temp twice before turning on to ensure the correct white temp is set. Its a bit of a pain because I need a delay in between the two events that set white and it slows the thing down a bit
Can anyone reproduce this?
a)
- bulb is at any color and dim value - on or off doesn't matter
- Run an event that sets white temp, eg 2750k 100%
- The correct white temp isn't being set. Sometimes its a bit off.
- The lifx ios app updates, but not with the set white temperature.
- Re run the event - now the correct temp is set and the lifx app reflects that
b)
- bulb is set to any white temp
- ran an event to change white temp
- correct temp is set
- the lifx app reflects this
