Thousands of errors
  • Thousands of errors
    Hi,
    I am getting thousands of these errors until I restart the plugin.
    There are no events within a minute or two of the first occurrence today involving the lights.
    Sep-20 08:18:35
    Error
    System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRALIGHTING3.hspi_plugin.LIFXCommandQueue()
    Sep-20 08:18:35
    Error
    Sep-20 08:18:35
    Error
    An error occured while processing the LIFX packet.
    What can I do to troubleshoot?
    Havent seen this for the past two days. Last week I got a new bulb, claimed it in the iPhone app, un plugged it and left it on the shelf for a while. Maybe the plugin didn't build the device properly or something but I've reconnected that new bulb and let it appear as a device - I haven't seen this since.
    Coincidence!?!
      I am going to redesign the plug-in so that I no longer use a broadcast packet. The plug-in will communicate with each bulb using it's own IP address. This should allow much faster packet communication as the plug-in will be able to communicate simultaneously with each bulb. If all goes well, I hope to be done in a few weeks.
      Ultrajones
        Sounds great I'm excited!
          The coding is pretty much done. I am going to let the code burn in for a day or two to see if anything unusual happens before posting the update.
          Ultrajones
            Great work! I'm happy to test if you need it before unleashing the update publicly.
              Ultrajones,
              I've just tested the new version. Bravo! Thank you.
              I did the power off test and it passed with flying colors!
