The UltraLighting3 HSPI original design used a UDP broadcast packet with an embedded target address within the packet so the LIFX LED bulb knew if the command was one it needed to respond to. Recent firmware updates on the LIFX LED bulbs now enabled direct communication to the bulb's IP address. I have just released UltraLighting3 HSPI version 3.0.6112.18549 which essentially adds a dedicated connection thread for each LIFX LED bulb. The result of this redesign is pretty amazing. As an example, I can create a HomeSeer event to set the color of all of my LIFX LED bulbs, adjust the brightness, then turn them on and they pretty much all respond at the exact same time
If you have tried this plug-in in the past, but were disappointed with the response time, please try this plug-in again. If you need to extend your trial, please create a HomeSeer helpdesk ticket and request a trial extension.
Ultrajones
Ultrajones
