API available?
  • API available?
    Hi, is there an API for this plugin yet?
    I'd like to be able to use a script to turn lights on/off, set brightness/color colour etc...
    No, not yet. However, you can create a script that controls the LIFX HomeSeer device which provides access to On/Off/Dim and On Last Level. However, access to the color controls is currently not available via the HomeSeer device.
    Ultrajones
      Here is a work around option using a script
      http://board.homeseer.com/showthread.php?t=178487
        That actually uses the lifx http api through the internet. Keep that in mind.
        You can to some degree control some of it through the standard homeseer device - as ultrajones has stated it doesn't control colour though.
        See an example I put here:
        http://board.homeseer.com/showpost.p...20&postcount=9
          Thanks for the tips!
