Not All Bulbs Visible
  • Not All Bulbs Visible
    I have two lights in a tv area, creatively named TV Area 1 and TV Area 2
    While I can control the bulbs on my Android LIFX app, only a single bulb TV Area 2 is available within HS3
    My log shows the following:
    Dec-31 7:54:09 AM	 	Warning	The LIFX bulb at IP address is no longer properly initialized. Flushing 1 commands from the command queue.
    Dec-31 7:54:08 AM	1	Error	System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at HSPI_ULTRALIGHTING3.hspi_lifx_light.LIFXReceiveQueue()
    Dec-31 7:54:08 AM	 	Error	An error occured while reading the LIFX packet.
    I'm running version 3.0.6158.37550
    Under the plug in, it does show one unknown LIFX light, which is not displayed on HS3
    For troubleshooting purposes, please disable then re-enable the plug-in. Once re-enabled, please check the lights to determine if they are both properly identified in the status web page.
    Ultrajones
      Am experiencing the same problems.
      Is there a way to completely remove all traces of the plug-in then reinstall fresh?
      Dec-31 10:07:30 AM	 	Warning	The LIFX bulb at IP address is no longer properly initialized. Flushing 1 commands from the command queue.
      Dec-31 10:07:30 AM	1	Error	System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at HSPI_ULTRALIGHTING3.hspi_lifx_light.LIFXReceiveQueue()
      Dec-31 10:07:30 AM	 	Error	An error occured while reading the LIFX packet.
        Something somehow got hosed in my install. Devices pop online for a while and then go offline. I can access the lights through my android lifx apps without issue. Can I somehow purge all the plugin data and start new?
        log simply fills up with:
        Dec-31 11:36:01 AM	 	Warning	The LIFX bulb at IP address is no longer properly initialized. Flushing 1 commands from the command queue.
        Dec-31 11:36:01 AM	1	Error	System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at HSPI_ULTRALIGHTING3.hspi_lifx_light.LIFXReceiveQueue()
          Still is acting flaky:
          Jan-01 2:18:28 PM	 	Warning	The LIFX bulb at IP address is no longer properly initialized. Flushing 1 commands from the command queue.
          Jan-01 2:18:28 PM	1	Error	System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at HSPI_ULTRALIGHTING3.hspi_lifx_light.LIFXReceiveQueue()
          by that i mean unreliable
          is there anything i can do to provide further information that might help pinpoint what the issue is?
            Do you have a firewall or anti-virus program getting in the way?
            Ultrajones
              Nothing on the HS3 box, it's a HomeTroller S6
                Under UltraLighting3 > UltraLighting3 > Options > LIFX Options, try setting the IP address of your primary interface, then restarting the plug-in.
                Ultrajones
                  I set it to the IP of my HS3 device and still see:
                  Jan-02 12:24:39 PM	 	Warning	The LIFX bulb at IP address is no longer properly initialized. Flushing 8 commands from the command queue.
                  Jan-02 12:24:39 PM	1	Error	System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at HSPI_ULTRALIGHTING3.hspi_lifx_light.LIFXReceiveQueue()
                  Jan-02 12:24:39 PM	 	Error	An error occured while reading the LIFX packet.
                    Please post a screenshot of UltraLighting3 > UltraLighting3 > Status
                    Ultrajones
                      I reset my HomeTrollerS6 and installed UltraLighting3. So far, no issues, but I'll continue to watch it.
                      How long does it take for your bulbs to go offline?
                      Ultrajones
                        Ultrajones
                        As requested
                          I haven't been able to find exactly when they go out. A number are offline now though controllable through the app
                            I have been running this on my HomeTroller S6 for a week and no errors whatsoever. I have 18 LIFX bulbs. Will continue to monitor.
                              Hi,
                              I am having a very similar situation. I can control all of my lights with my LIFX IOS app all of the time, but occasionally several LIFX bulbs become uninitialized/unavailable to HS3. There is no rhyme or reason as to when or why except that it seems to be nearly every time my wife wants to use them!
                              What would cause a LIFX bulb to become uninitialized/unavailable to HS3 and still be available to the phone app?
                              Rob
