Not All Bulbs Visible
  • Ultrajones
    The latest version still does not fix the issue with the bulbs going offline. I was able to confirm the UDP listeners were still active on my HomeSeer system, but the bulbs are not sending back a response. I may have to escalate to the LIFX vendor and ask them what the deal is.
    Regards,
    Ultrajones
  • Ultrajones
    Please download the version I just uploaded to the HomeSeer updater. I modified the UDP listeners so they time-out and re-initialize after no activity. I also added a "Last Send Event" and "Last Receive Event" for both the plug-in and individual bulbs so we can determine if the UDP listeners are failing after a period of time.
    Regards,
    Ultrajones
  • outbackrob
    I am having a very similar situation. I can control all of my lights with my LIFX IOS app all of the time, but occasionally several LIFX bulbs become uninitialized/unavailable to HS3. There is no rhyme or reason as to when or why except that it seems to be nearly every time my wife wants to use them!
    What would cause a LIFX bulb to become uninitialized/unavailable to HS3 and still be available to the phone app?
    Rob
  • Ultrajones
    I have been running this on my HomeTroller S6 for a week and no errors whatsoever. I have 18 LIFX bulbs. Will continue to monitor.
  • macrho
    Originally posted by Ultrajones View Post
    I reset my HomeTrollerS6 and installed UltraLighting3. So far, no issues, but I'll continue to watch it.
    How long does it take for your bulbs to go offline?
    I haven't been able to find exactly when they go out. A number are offline now though controllable through the app
  • macrho
    Please post a screenshot of UltraLighting3 > UltraLighting3 > Status
    Ultrajones
    As requested
  • Ultrajones
    Regards,
    Ultrajones
  • Ultrajones
    Regards,
    Ultrajones
  • macrho
    I set it to the IP of my HS3 device and still see:
    Jan-02 12:24:39 PM	 	Warning	The LIFX bulb at IP address is no longer properly initialized. Flushing 8 commands from the command queue.
    Jan-02 12:24:39 PM	1	Error	System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at HSPI_ULTRALIGHTING3.hspi_lifx_light.LIFXReceiveQueue()
    Jan-02 12:24:39 PM	 	Error	An error occured while reading the LIFX packet.
  • Ultrajones
    Under UltraLighting3 > UltraLighting3 > Options > LIFX Options, try setting the IP address of your primary interface, then restarting the plug-in.
    Regards,
    Ultrajones
  • macrho
    Do you have a firewall or anti-virus program getting in the way?
    Nothing on the HS3 box, it's a HomeTroller S6
  • Ultrajones
    Regards,
    Ultrajones
  • macrho
    Still is acting flaky:
    Jan-01 2:18:28 PM	 	Warning	The LIFX bulb at IP address is no longer properly initialized. Flushing 1 commands from the command queue.
    Jan-01 2:18:28 PM	1	Error	System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at HSPI_ULTRALIGHTING3.hspi_lifx_light.LIFXReceiveQueue()
    by that i mean unreliable
    is there anything i can do to provide further information that might help pinpoint what the issue is?
  • macrho
    Something somehow got hosed in my install. Devices pop online for a while and then go offline. I can access the lights through my android lifx apps without issue. Can I somehow purge all the plugin data and start new?
    log simply fills up with:
    Dec-31 11:36:01 AM	 	Warning	The LIFX bulb at IP address is no longer properly initialized. Flushing 1 commands from the command queue.
    Dec-31 11:36:01 AM	1	Error	System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at HSPI_ULTRALIGHTING3.hspi_lifx_light.LIFXReceiveQueue()
  • macrho
    Am experiencing the same problems.
    Is there a way to completely remove all traces of the plug-in then reinstall fresh?
    Dec-31 10:07:30 AM	 	Warning	The LIFX bulb at IP address is no longer properly initialized. Flushing 1 commands from the command queue.
    Dec-31 10:07:30 AM	1	Error	System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.ReceiveFrom(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, EndPoint& remoteEP) at System.Net.Sockets.UdpClient.Receive(IPEndPoint& remoteEP) at HSPI_ULTRALIGHTING3.hspi_lifx_light.LIFXReceiveQueue()
    Dec-31 10:07:30 AM	 	Error	An error occured while reading the LIFX packet.
