Tabletop Controller not showing up as a device
  • Tabletop Controller not showing up as a device
    I have a pair of older Simply Automated UCT-08 devices (Tabletop Controller 8-Button) and when I was using HS2 these showed up as devices that I could control. At the time, I wasn't using your UPB plugin, but HS's--so that's the next thing that different.
    Anyway, is there any chance that I can tweak something with your plug-in or upe file to get these to show up as devices? The downside to these is that they are only an output-only controller normally, except that they have status lights that can be controlled. Unfortunately its easy to get the status lights out of sync with the controller, so I was using HS to keep them in sync (happens, for example, when All Lights Off is activated).
    I don't mind if I need to manually tweak something, like in the upe file, nor do I mind if they show up with the wrong device type, etc.
    Below is what one looks like in the upe file.
    If there's anything I can do to get these to show up in HS3, that would be great.
    3,30,120,4,15,4,15,1,1,8,8,Master Bedroom,Jim's Control,1
    12,0,1b,0e,10,11,12,ff,ff,1e,1b,66,55,32,44,0e,65,87
    12,16,32,44,10,65,87,32,44,11,65,87,32,44,12,55,77,55
    12,32,ff,ff,65,87,32,44,ff,65,65,65,ff,1e,55,55,ff,ff
    12,48,92,81,81,81,81,00,00,81,ff,ff,ff,ff,ff,ff,ff,ff
    12,64,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,2f,84,ff
    12,80,22,00,ff,22,64,ff,23,00,05,23,64,05,24,ff,ff,21
    12,96,ff,ff,20,ff,ff,22,00,00,22,64,00,22,00,01,22,64
    12,112,01,22,00,08,22,64,08,25,1e,ff,00,00,00,ff,ff,ff
    12,128,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
    12,144,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
    12,160,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
    12,176,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
    19,30,0,1,Jim's Control,Keypad6
    8,0,30,0,0
    6,0,0,30,27,6,5,3,4,6,5,2,4,27,146
    6,0,1,30,14,6,8,3,4,5,7,2,4,14,129
    6,0,2,30,16,6,8,3,4,5,7,2,4,16,129
    6,0,3,30,17,6,8,3,4,5,7,2,4,17,129
    6,0,4,30,18,5,7,5,15,5,7,5,15,18,129
    6,0,5,30,255,6,8,3,4,5,7,2,4,255,0
    6,0,6,30,255,6,6,6,15,5,5,5,15,255,0
    6,0,7,30,30,5,5,15,15,5,5,15,15,30,129
    17,0,0,30,E
    17,0,1,30,F
    17,0,2,30,G
    17,0,3,30,H
    17,0,4,30,I
    17,0,5,30,J
    17,0,6,30,K
    17,0,7,30,L
    please post or send me the full .upe file, thanks.
      Thanks. I just PM'd you with a link to it on my OneDrive.
        please test version 3.0.0.43 available here: https://forums.homeseer.com/showthre...01#post1088701
        It should create devices like in the screenshot below:
          Wow! That was quick. I will test this tonight when I get home.
          Thanks!
            Hey Spud,
            OK, I got it installed (took me a while to figure out where the "HS3 Application Folder" resides on my Raspberry Pi HS3 system).
            It didn't come up cleanly after the upgrade, but disabling and re-enabling the plug-in fixed that.
            Now I am seeing the controllers, but not all of the buttons. Is there a reason for that? On both "Kate's" and "Jim's" I am not seeing buttons 6 & 7.
            Thoughts?
            Thanks a lot for your quick work on this too.
            Jim
              buttons 6 and 7 are not created because there is no links associated to these butons
                Ah, that makes sense. The other UPB plug-in only allowed me to manipulate the status lights and not the buttons, so they gave me all of the status lights regardless of if they were assigned or not.
                Thanks for your time on this,
                Jim
