UPBSpud Stops responding.
  • UPBSpud Stops responding.
    I just finished a clean HS3 install and configured everything and I keep getting the following in the log after a couple minutes after starting HS. Things will work for a couple minutes and then all UPB lighting commands stop responding. Not sure what is causing this.k
    System is running on a Windows 10 computer
    Nov-21 10:30:32 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
    Nov-21 10:30:02 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
    Nov-21 10:29:41 PM Error Calling SetIOMulti in plugin UPBSpud:Object reference not set to an instance of an object.
    Nov-21 10:29:32 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
    Nov-21 10:29:11 PM Error Calling SetIOMulti in plugin UPBSpud:Object reference not set to an instance of an object.
    Nov-21 10:29:05 PM Device Control Device: Kitchen Light to Off (0) by/from: CAPI Control Handler
    Nov-21 10:28:41 PM Device Control Device: Kitchen Light to Off (0) by/from: CAPI Control Handler
    Nov-21 10:16:38 PM Device Control Device: Kitchen Light to On (100) by/from: CAPI Control Handler
    I just noticed this error message:
    Starting up....
    11/22/2018 6:53:52 AM ~!~Error~!~Warning, Cannot load EXE file (possibly missing dependencies) HSPI_UPBSpud.exe: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.Warning, Error details with EXE HSPI_UPBSpud.exe: Could not load file or assembly 'UPB4CSharp, Version=1.0.1.8, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    I've tried removing the plugin and reinstalling it but that doesn't seem to of had any impact.
      Have you installed the plugin from the updater?
      Do you have UPB4CSharp.dll in bin/UPBSpud?
      If you have also this dll in the root folder or in bin, delete it.
        I have UPB4CSharp.dll in bin/UPBSpud
        There is no other copy of the file in bin or the root folder.
        I downloaded and installed the plugin from the PLUG-INS menu tab at the top of the HS user interface.
        In the Plug-in Status on the Installed Plug-ins section the following error message is displayed:
        CRITICAL: Failed to get InterfaceStatus from UPBSpud: Object reference not set to an instance of an object.
          I have no idea what could be the problem.
          Can you load other plugins?
          Could you post all the logs you get when you enable the plugin?
          If you want me to have a look install TeamViewer or similar and send me the credentials at spud.webb.4@gmail.com
            I have the HS Z-Wave plugin installed and working properly and UltraM1G3 which also is working fine.
            Here is the complete log since the last restart of HS up to the point the plugin failed. The log entry at 4:37:55 PM never executed and then the plugin failed.
            I'll check in to TeamViewer
            I'm also considering starting all over the reformat the hard drive and reinstall everything, but I'd prefer not to do that.
            Nov-22 4:39:12 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
            Nov-22 4:38:42 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
            Nov-22 4:38:25 PM Error Calling SetIOMulti in plugin UPBSpud:Object reference not set to an instance of an object.
            Nov-22 4:37:55 PM Device Control Device: Living Room Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:35:36 PM Device Control Device: Kitchen Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:32:56 PM Device Control Device: Kitchen Light to On (100) by/from: CAPI Control Handler
            Nov-22 4:29:54 PM Device Control Device: Living Room Light to On (100) by/from: CAPI Control Handler
            Nov-22 4:28:37 PM Device Control Device: Virtual Night Mode to Off (0)
            Nov-22 4:28:37 PM Device Control Device: MSTR Bath Towel Warmer to On (100)
            Nov-22 4:28:37 PM Event Event Trigger "Security System Events Alarm Deactivated"
            Nov-22 4:28:30 PM Device Control Device: Virtual Morning Routine to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: Hall Bath Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: Hall Bath Exhaust Fan to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: Office Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: BDRM 3 Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: BDRM 2 Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: BDRM 2 Closet Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: BDRM 2 Outlet 01 to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: Garage Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: MSTR Bath Shower Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: MSTR Bath Exhaust Fan to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: MSTR Bath Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: MSTR BD Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: Hall Light-1 to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: Front entry Light-1 to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: Kitchen Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: Dining room Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: Living Room Exterior Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: Living Room Light to Off (0) by/from: CAPI Control Handler
            Nov-22 4:28:30 PM Device Control Device: Node 2 Z-Wave Front Door Lock to Lock (255)
            Nov-22 4:28:30 PM Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/DevicesOff.txt
            Nov-22 4:28:30 PM Event Event Trigger "Light Events Devices Off"
            Nov-22 4:28:19 PM Device Control Device: Kitchen Light to On (100) by/from: CAPI Control Handler
            Nov-22 4:27:44 PM Z-Wave Starting Z-Wave Polling for Network F7DFEC69...
            Nov-22 4:27:43 PM TTS Speak ():Welcome to Home-Seer
            Nov-22 4:27:42 PM Speaker Speaker host added, Name: HOMESEER Instance: Default IP address: 127.0.0.1
            Nov-22 4:27:40 PM UPBSpud INFO Checking HS Devices Completed
            Nov-22 4:27:39 PM UPBSpud INFO Checking HS Devices Started
            Nov-22 4:27:39 PM UPBSpud INFO Import of UPStart file completed
            Nov-22 4:27:39 PM UPBSpud INFO Import of UPStart file started
            Nov-22 4:27:39 PM Starting Plug-In Plugin UPBSpud started successfully in 27 milliseconds
            Nov-22 4:27:39 PM UPBSpud INFO UPBSpud version 3.0.0.44
            Nov-22 4:27:39 PM Starting Plug-In Initializing plugin UPBSpud ...
            Nov-22 4:27:39 PM Info Plugin UPBSpud has connected. IP:127.0.0.1:52357
            Nov-22 4:27:39 PM Plug-In Finished initializing plug-in UPBSpud
            Nov-22 4:27:20 PM Starting Plug-In Plugin UltraM1G3 started successfully in 6201 milliseconds
            Nov-22 4:27:20 PM Informational UltraM1G3 version 3.0.6846.19195 initialization complete.
            Nov-22 4:27:18 PM Z-Wave ************************************************************ *******************
            Nov-22 4:27:18 PM Z-Wave STARTUP COMPLETE: All configured interfaces were successfully initialized.
            Nov-22 4:27:16 PM Web Server Web Server authorized local login successful from: 192.168.1.64 User: default
            Nov-22 4:27:16 PM Z-Wave Z-Wave Controller: ............................................................ ..........
            Nov-22 4:27:16 PM Z-Wave Z-Wave Controller: .............................. FINISHED ..............................
            Nov-22 4:27:16 PM Z-Wave Z-Wave Controller is the SIS for the network.
            Nov-22 4:27:16 PM Z-Wave Z-Wave Controller There is a SUC/SIS in the network.
            Nov-22 4:27:16 PM Z-Wave Z-Wave Controller Controller is static lib.
            Nov-22 4:27:16 PM Z-Wave Z-Wave Controller Controller chip type is ZW050x.
            Nov-22 4:27:16 PM Z-Wave The interface's security support has been set.
            Nov-22 4:27:16 PM Z-Wave Z-Wave Controller: Found 3 Z-Wave nodes in interface node ID 1 (Z-Wave Controller)
            Nov-22 4:27:16 PM Z-Wave Z-Wave Controller: Z-Wave interface node ID: 1, Home ID: F7DFEC69
            Nov-22 4:27:16 PM Z-Wave Z-Wave Controller: Z-Wave Serial API version: 5
            Nov-22 4:27:16 PM Z-Wave Z-Wave Controller: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
            Nov-22 4:27:16 PM Z-Wave Z-Wave Controller: Controller firmware version: 4.32
            Nov-22 4:27:15 PM Info System connected to MyHS Service successfully with license ID 113253.
            Nov-22 4:27:14 PM Info System connected to MyHS Service, waiting for acknowledge...
            Nov-22 4:27:14 PM Startup Start up complete.
            Nov-22 4:27:14 PM Startup HSSentry is disabled in Setup, sentry will not be started.
            Nov-22 4:27:14 PM Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...
            Nov-22 4:27:14 PM Startup (Startup.vb script) Scripting is OK and is now running Startup.vb
            Nov-22 4:27:14 PM Startup Starting Event Scheduler...
            Nov-22 4:27:14 PM Startup Running the startup script Startup.vb
            Nov-22 4:27:14 PM Startup Starting Find service...
            Nov-22 4:27:14 PM Startup Updater services starting...
            Nov-22 4:27:14 PM Database Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
            Nov-22 4:27:14 PM Speech Listening for remote speaker connections on port 10401
            Nov-22 4:27:14 PM Startup Initializing Speaker Client Interface
            Nov-22 4:27:14 PM Startup Start automation engine...
            Nov-22 4:27:13 PM Z-Wave Z-Wave Controller: Getting node information from controller...
            Nov-22 4:27:13 PM Z-Wave Z-Wave Controller: The Z-Wave API Execution Thread was Started or Restarted.
            Nov-22 4:27:13 PM Z-Wave Z-Wave Controller: The Z-Wave Command Execution Thread was Started or Restarted.
            Nov-22 4:27:13 PM Z-Wave Z-Wave Controller: ----------------------------------------------------------------------
            Nov-22 4:27:13 PM Z-Wave Initializing Z-Wave interface Z-Wave Controller (HomeSeer SmartStick +) on COM3
            Nov-22 4:27:13 PM Z-Wave Z-Wave Controller: ============================================================ ==========
            Nov-22 4:27:13 PM Z-Wave 465 Simple AV Control Command Class Control Commands have been loaded successfully.
            Nov-22 4:27:13 PM Z-Wave 0 event triggers were loaded from HomeSeer.
            Nov-22 4:27:13 PM Z-Wave 0 event actions were loaded from HomeSeer.
            Nov-22 4:27:13 PM Starting Plug-In Initializing plugin UltraM1G3 ...
            Nov-22 4:27:13 PM Starting Plug-In Plugin Z-Wave started successfully in 450 milliseconds
            Nov-22 4:27:13 PM Z-Wave 9 total Z-Wave Data Objects loaded.
            Nov-22 4:27:13 PM Z-Wave Network F7DFEC69 has 9 device data elements.
            Nov-22 4:27:13 PM Z-Wave 1 Networks were restored from the data in the database... Building data connections.
            Nov-22 4:27:13 PM Z-Wave Loading Z-Wave Data Objects...
            Nov-22 4:27:13 PM Z-Wave 1 total Z-Wave Network Objects loaded.
            Nov-22 4:27:13 PM Z-Wave Loading Z-Wave Network Objects...
            Nov-22 4:27:13 PM Z-Wave Database: Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db
            Nov-22 4:27:13 PM Z-Wave InitIO called, plug-in version 3.0.1.248 is being initialized...
            Nov-22 4:27:13 PM Starting Plug-In Initializing plugin Z-Wave ...
            Nov-22 4:27:13 PM Startup Creating ASP.NET application host...
            Nov-22 4:27:13 PM Info Plugin Z-Wave has connected. IP:127.0.0.1:52251
            Nov-22 4:27:13 PM Web Server Web Server started on port 80
            Nov-22 4:27:13 PM Web Server Local IP address (subnet) is: 192.168.1.95 (255.255.255.0)
            Nov-22 4:27:13 PM Info Plugin UltraM1G3 has connected. IP:127.0.0.1:52253
            Nov-22 4:27:13 PM Startup HStouch server started, waiting for clients to connect.
            Nov-22 4:27:13 PM HSTouch Server Server started on port 10200
            Nov-22 4:27:13 PM Plug-In Finished initializing plug-in UltraM1G3
            Nov-22 4:27:13 PM Plug-In Finished initializing plug-in Z-Wave
            Nov-22 4:27:13 PM Startup Initializing Plug-Ins
            Nov-22 4:27:13 PM Plug-In Found plug-in: Z-Wave, version: 3.0.1.248
            Nov-22 4:27:12 PM Plug-In Found plug-in: UPBSpud, version: 3.0.0.44
            Nov-22 4:27:12 PM Plug-In Found plug-in: UltraM1G3, version: 3.0.6846.19195
            Nov-22 4:27:12 PM Startup Checking for available plug-ins
            Nov-22 4:27:12 PM Info Remote plug-in API interface started on port 10400
            Nov-22 4:27:12 PM Startup This version of HomeSeer is registered as a HS3PRO version.
            Nov-22 4:27:12 PM Startup Creating Speaker Client Interface Object...
            Nov-22 4:27:12 PM Startup HomeSeer version is: 3.0.0.435
            Nov-22 4:27:12 PM Load Config Loading TIMERS...
            Nov-22 4:27:12 PM Load Config Loading COUNTERS...
            Nov-22 4:27:12 PM Load Config 23 total events loaded.
            Nov-22 4:27:12 PM Load Config Loading Events...
            Nov-22 4:27:12 PM Load Config Loading Event Groups...
            Nov-22 4:27:12 PM Load Config 68 total devices loaded.
            Nov-22 4:27:12 PM Database Loading Devices...
            Nov-22 4:27:12 PM Database Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
            Nov-22 4:27:12 PM Startup Loading configuration file ...
            Nov-22 4:27:12 PM Startup Database SAVE process started.
            Nov-22 4:27:12 PM Startup Local voice recognition class started.
            Nov-22 4:27:12 PM Startup HSPhone external interface class started.
            Nov-22 4:27:12 PM Startup Plug-In Interface class started.
            Nov-22 4:27:12 PM Startup E-Mail RECEIVE class started.
            Nov-22 4:27:12 PM Startup E-Mail SEND class started.
            Nov-22 4:27:12 PM Startup Web server class started.
            Nov-22 4:27:12 PM Startup Application interface class started.
            Nov-22 4:27:12 PM Startup COM port classes started.
            Nov-22 4:27:12 PM Startup Creating Class Objects...
            Nov-22 4:27:12 PM System Ending plug-in process HSPI_UPBSpud
            Nov-22 4:27:12 PM Startup ************************************************************ ********************
            Nov-22 4:27:12 PM Startup HomeSeer version 3.0.0.435 Edition: HS3 Pro Starting Now
            Nov-22 4:27:12 PM Startup Settings Loaded.
              Could you set the log level to Debug from the UPBSpud config page, and then restart the plugin.
                Below is the log with debugging info on. I noticed the error regarding COM4. That is correct because it is the same setting that UPStart uses and that functions without any problems.
                Nov-23 10:31:09 AM TTS Speak ():Welcome to Home-Seer
                Nov-23 10:31:08 AM Z-Wave Starting Z-Wave Polling for Network F7DFEC69...
                Nov-23 10:31:02 AM Warning A database 'save' was called less than 5 minutes after the system was started - this is being ignored or re-queued to promote database integrity.
                Nov-23 10:30:44 AM UPBSpud DEBUG PIMADAPTER:: The device does not recognize the command.
                Nov-23 10:30:44 AM UPBSpud ERROR PIMADAPTER:: Unable to open PIM port COM4
                Nov-23 10:30:44 AM UPBSpud DEBUG UPB_MGR:: Activating media adapter
                Nov-23 10:30:44 AM UPBSpud DEBUG UPB_MGR:: Initializing media adapter
                Nov-23 10:30:44 AM Starting Plug-In Plugin UPBSpud started successfully in 24 milliseconds
                Nov-23 10:30:44 AM UPBSpud INFO UPBSpud version 3.0.0.44
                Nov-23 10:30:44 AM Starting Plug-In Initializing plugin UPBSpud ...
                Nov-23 10:30:44 AM Starting Plug-In Plugin UltraM1G3 started successfully in 6282 milliseconds
                Nov-23 10:30:44 AM Informational UltraM1G3 version 3.0.6846.19195 initialization complete.
                Nov-23 10:30:41 AM Z-Wave ************************************************************ *******************
                Nov-23 10:30:41 AM Z-Wave STARTUP COMPLETE: All configured interfaces were successfully initialized.
                Nov-23 10:30:41 AM Web Server Web Server authorized local login successful from: 192.168.1.95 User: default
                Nov-23 10:30:40 AM Z-Wave Z-Wave Controller: ............................................................ ..........
                Nov-23 10:30:40 AM Z-Wave Z-Wave Controller: .............................. FINISHED ..............................
                Nov-23 10:30:40 AM Z-Wave Z-Wave Controller is the SIS for the network.
                Nov-23 10:30:40 AM Z-Wave Z-Wave Controller There is a SUC/SIS in the network.
                Nov-23 10:30:40 AM Z-Wave Z-Wave Controller Controller is static lib.
                Nov-23 10:30:40 AM Z-Wave Z-Wave Controller Controller chip type is ZW050x.
                Nov-23 10:30:40 AM Z-Wave The interface's security support has been set.
                Nov-23 10:30:40 AM Z-Wave Z-Wave Controller: Found 3 Z-Wave nodes in interface node ID 1 (Z-Wave Controller)
                Nov-23 10:30:40 AM Z-Wave Z-Wave Controller: Z-Wave interface node ID: 1, Home ID: F7DFEC69
                Nov-23 10:30:40 AM Z-Wave Z-Wave Controller: Z-Wave Serial API version: 5
                Nov-23 10:30:40 AM Z-Wave Z-Wave Controller: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
                Nov-23 10:30:40 AM Z-Wave Z-Wave Controller: Controller firmware version: 4.32
                Nov-23 10:30:39 AM Device Control Device: Node 4 Z-Wave Switch to On (255)
                Nov-23 10:30:39 AM Event Event Trigger "Z-Wave Outlet Air Freshener Schedule"
                Nov-23 10:30:38 AM Info System connected to MyHS Service successfully with license ID 113253.
                Nov-23 10:30:38 AM Info System connected to MyHS Service, waiting for acknowledge...
                Nov-23 10:30:38 AM Startup Start up complete.
                Nov-23 10:30:38 AM Startup HSSentry is disabled in Setup, sentry will not be started.
                Nov-23 10:30:38 AM Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...
                Nov-23 10:30:38 AM Startup (Startup.vb script) Scripting is OK and is now running Startup.vb
                Nov-23 10:30:38 AM Startup Starting Event Scheduler...
                Nov-23 10:30:38 AM Startup Running the startup script Startup.vb
                Nov-23 10:30:38 AM Startup Starting Find service...
                Nov-23 10:30:38 AM Startup Updater services starting...
                Nov-23 10:30:38 AM Database Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
                Nov-23 10:30:38 AM Speech Listening for remote speaker connections on port 10401
                Nov-23 10:30:38 AM Startup Initializing Speaker Client Interface
                Nov-23 10:30:38 AM Startup Start automation engine...
                Nov-23 10:30:38 AM Z-Wave Z-Wave Controller: Getting node information from controller...
                Nov-23 10:30:38 AM Z-Wave Z-Wave Controller: The Z-Wave API Execution Thread was Started or Restarted.
                Nov-23 10:30:37 AM Z-Wave Z-Wave Controller: The Z-Wave Command Execution Thread was Started or Restarted.
                Nov-23 10:30:37 AM Z-Wave Z-Wave Controller: ----------------------------------------------------------------------
                Nov-23 10:30:37 AM Z-Wave Initializing Z-Wave interface Z-Wave Controller (HomeSeer SmartStick +) on COM3
                Nov-23 10:30:37 AM Z-Wave Z-Wave Controller: ============================================================ ==========
                Nov-23 10:30:37 AM Z-Wave 465 Simple AV Control Command Class Control Commands have been loaded successfully.
                Nov-23 10:30:37 AM Z-Wave 0 event triggers were loaded from HomeSeer.
                Nov-23 10:30:37 AM Z-Wave 0 event actions were loaded from HomeSeer.
                Nov-23 10:30:37 AM Starting Plug-In Initializing plugin UltraM1G3 ...
                Nov-23 10:30:37 AM Starting Plug-In Plugin Z-Wave started successfully in 417 milliseconds
                Nov-23 10:30:37 AM Z-Wave 9 total Z-Wave Data Objects loaded.
                Nov-23 10:30:37 AM Z-Wave Network F7DFEC69 has 9 device data elements.
                Nov-23 10:30:37 AM Z-Wave 1 Networks were restored from the data in the database... Building data connections.
                Nov-23 10:30:37 AM Z-Wave Loading Z-Wave Data Objects...
                Nov-23 10:30:37 AM Z-Wave 1 total Z-Wave Network Objects loaded.
                Nov-23 10:30:37 AM Z-Wave Loading Z-Wave Network Objects...
                Nov-23 10:30:37 AM Startup Creating ASP.NET application host...
                Nov-23 10:30:37 AM Web Server Web Server started on port 80
                Nov-23 10:30:37 AM Z-Wave Database: Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db
                Nov-23 10:30:37 AM Web Server Local IP address (subnet) is: 192.168.1.95 (255.255.255.0)
                Nov-23 10:30:37 AM Info Plugin UPBSpud has connected. IP:127.0.0.1:53488
                Nov-23 10:30:37 AM Z-Wave InitIO called, plug-in version 3.0.1.248 is being initialized...
                Nov-23 10:30:37 AM Starting Plug-In Initializing plugin Z-Wave ...
                Nov-23 10:30:37 AM Info Plugin UltraM1G3 has connected. IP:127.0.0.1:53486
                Nov-23 10:30:37 AM Info Plugin Z-Wave has connected. IP:127.0.0.1:53484
                Nov-23 10:30:37 AM Startup HStouch server started, waiting for clients to connect.
                Nov-23 10:30:37 AM HSTouch Server Server started on port 10200
                Nov-23 10:30:37 AM Plug-In Finished initializing plug-in UPBSpud
                Nov-23 10:30:37 AM Plug-In Finished initializing plug-in UltraM1G3
                Nov-23 10:30:37 AM Plug-In Finished initializing plug-in Z-Wave
                Nov-23 10:30:37 AM Startup Initializing Plug-Ins
                Nov-23 10:30:37 AM Plug-In Found plug-in: Z-Wave, version: 3.0.1.248
                Nov-23 10:30:37 AM Plug-In Found plug-in: UPBSpud, version: 3.0.0.44
                Nov-23 10:30:37 AM Plug-In Found plug-in: UltraM1G3, version: 3.0.6846.19195
                Nov-23 10:30:37 AM Startup Checking for available plug-ins
                Nov-23 10:30:37 AM Info Remote plug-in API interface started on port 10400
                Nov-23 10:30:37 AM Startup This version of HomeSeer is registered as a HS3PRO version.
                Nov-23 10:30:37 AM Startup Creating Speaker Client Interface Object...
                Nov-23 10:30:37 AM Startup HomeSeer version is: 3.0.0.435
                Nov-23 10:30:37 AM Load Config Loading TIMERS...
                Nov-23 10:30:37 AM Load Config Loading COUNTERS...
                Nov-23 10:30:37 AM Load Config 23 total events loaded.
                Nov-23 10:30:37 AM Load Config Loading Events...
                Nov-23 10:30:37 AM Load Config Loading Event Groups...
                Nov-23 10:30:37 AM Load Config 68 total devices loaded.
                Nov-23 10:30:37 AM Database Loading Devices...
                Nov-23 10:30:37 AM Database Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
                Nov-23 10:30:37 AM Startup Loading configuration file ...
                Nov-23 10:30:37 AM Startup Database SAVE process started.
                Nov-23 10:30:37 AM Startup Local voice recognition class started.
                Nov-23 10:30:37 AM Startup HSPhone external interface class started.
                Nov-23 10:30:37 AM Startup Plug-In Interface class started.
                Nov-23 10:30:37 AM Startup E-Mail RECEIVE class started.
                Nov-23 10:30:37 AM Startup E-Mail SEND class started.
                Nov-23 10:30:37 AM Startup Web server class started.
                Nov-23 10:30:37 AM Startup Application interface class started.
                Nov-23 10:30:37 AM Startup COM port classes started.
                Nov-23 10:30:37 AM Startup Creating Class Objects...
                Nov-23 10:30:37 AM Startup ************************************************************ ********************
                Nov-23 10:30:37 AM Startup HomeSeer version 3.0.0.435 Edition: HS3 Pro Starting Now
                Nov-23 10:30:37 AM Startup Settings Loaded.
                  Do you have UPStart runnning? A COM port can be accessed only by one program, so you need to shutdown UPstart when the UPBSpud plugin is running.
                    I know you can't have UPStart open at the same time the plugin is running.
                    I have noticed with debugging turned on the plugin seems to be in an endless loop constantly repeating the following line:
                    Even if I disable the plugin it says it has been started remotely and it continues looping the same message. The log fills with thousands of these entries and the only way to stop it is to completely shut down HS.
                    I've installed TeamViewer and am available any times for you to see if you can identify what might be the issue. Let me know when you are available and I will send you the access information.
                      I'm available right now
                        Just emailed the TeamViewer info to you.
                          spud - just wanted to follow up on the status. I replaced the PIM with the one you suggested and have been successfully testing for the past few days. That appears to have been the cause of the issue. The system has been executing events without fail and there hasn't been on instance of it freezing up. I appreciate your help with this.
                            Thanks for the follow up.
                            For others reading this, David was using the UMC-DB9 from SA with an additional Serial to USB adapter, this is not supported by this plugin even if it works with UPStart. If you need a USB PIM go with PIM-U from PulseWorx.
                            I have updated the user guide with the list of supported interfaces
