Poll Device State, Spud UPB plugin
    Spud,
    Thanks for your UPB plugin, which has served us well for several years.
    Finally getting around to tuning up the status reporting of UPB devices. When users turn on some devices manually (by a wall switch, for example), the status change is not reported. HS3 thinks the light is off. We have just ignored this for a while. Now looking at this, trying to clean up the status reporting.
    I tried to poll UPB status with the 'Poll Device State' action from the plugin manual. First triggered the event manually. Then triggered the event from a virtual device. The status shown for my test UPB device did not change (a light I had switched ON manually from a wall switch and was reported by HS3 as OFF does not update to ON). Then looked at the log (see below). The poll device state action throws an error. Looking forward to any help to resolve this.
    Dean
    Log
    Jan-04 20:04:12 Device Control Device: Utility Controls Update ON/OFF Status to Disabled (0) by/from: CAPI Control Handler
    Jan-04 20:03:48 Error Event Actions Poll Status of ALL UPB Devices plugin action failed:Input string was not in a correct format.
    Jan-04 20:03:48 Event Event Trigger "Actions Poll Status of ALL UPB Devices"
    Jan-04 20:03:48 Device Control Device: Utility Controls Update ON/OFF Status to Enabled (1) by/from: CAPI Control Handler
    Jan-04 20:01:57 Error Event Actions Poll Status of ALL UPB Devices plugin action failed:Input string was not in a correct format.
    Jan-04 20:01:57 Event Event Trigger "Actions Poll Status of ALL UPB Devices"
    Jan-04 20:00:38 Plug-In Finished initializing plug-in ImperiHome
    Hi 1DB I am having a problem sending the Upstart file from "Upstart " to the Spud interface
    the steps I have taken
    1- wrote Upstart program
    2- export file from Upstart , but the file only goes to my computer ( I can put the file anywhere computer , fob etc ) but the spud file states either no file or can not open / read , the log shows no file imported. I believe iam missing one simple step in making the file transfer
    My goal is tieing leviton , homeseer , Alexa , UPB / HLC & Somfy URTSII to UPB key pads , I have everything working but the spud interface
    any help any any one can provide would be greatly appreciated
    Thank you Biff
      In UpStart, do you have the devices defined so that they report any local changes?
      tenholde
        What do you get when you test the communication with the device using UpStart?
        HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
          More details would be useful. It sounds like you are running UpStart on a different computer than the one running HS, is that correct? Do you get any errors when you try to export the upe file from UpStart? Does the upe file show up in File Explorer at the location where you think your are exporting it?
            Hi Biff,
            You are on the right track: UPB works well with HomeSeer. Others on this forum are more qualified than I, but with the help of Spud's user manual and Upstart and no particular rocket science, I can control my UPB device network on HomeSeer. I have learned that my UPB devices can do more than I knew when I installed them during renovation of our house. I have also learned that you need to configure each and every button of every device in Upstart with a robust (complete and unambiguous) naming convention. Save your configuration naming 'model' in a spreadsheet (a google sheet works great for this). You can later edit device names in HS3 and do lots of interesting things with your UPB devices. But, you can't export your updated UPB configuration back to upstart. You lose your changes. You have to start over. Your "real" configuration benchmark is the Upstart export file. You can change names and do lots of stuff in HS3, but when you need to update your "real" configuration, you will have to type in the changes manually into upstart.
            If you make changes to UPB device names, etc, in HS3 you need to track them. One way is to copy the device list from HS3 and paste it into a spreadsheet. You will need to reconcile that with your original Upstart configuration spreadsheet. This is messy. I am in the middle of this now, having fallen into the trap of "premature optimization" myself.
            So my advice, once you get things running is: Configure your devices in upstart, [and once your porting to HS3 is working] copy your original config into a spreadsheet as soon as you port it to HS3 and before you make any changes. Then test things, see if you got them all, check this carefully, go back to upstart if you need to pick up any missing devices, and then, port again to HS3, make a new spreadsheet of your devices, and then start developing from there.
            BECAUSE, when you add Alexa to the mix, you are going to hit another "naming convention" wall -- which will require you to consider "names, floors and rooms" again from the perspective of the non-technical person who just wants to use a particular device. HomeSeer UPB (and and Z-Wave, etc) device grouping takes on a whole new 'spin' when you have more than one Alexa device looking into your network through the lens of the Alexa namespace, technical features and operating conventions.
            Now: back to the problem of getting UPB into HS3:
            Instead of asking you 20 questions up front, let's make sure we're on the same page -- starting with the first page of Spud's UPB user manual (see below). What PIM are you using? Have you followed the procedure that Spud recommended? Think through this page step by step and see if you can spot the problem. If something seems unclear, name it and let's see if someone here can help.
            P.S., I am using an HAI UPB PIM with a serial interface. I run Upstart on a win7 laptop. When I am running upstart, the serial plug from the PIM is in the laptop serial port. When I am ready to control UPB from homeseer, I copy the upstart export file to my HomeSeer win7 machine and plug the serial connector of the PIM into a serial port on my HomeSeer machine. I manage the serial ports by trial and error mostly. Put the plug where it works. I don't know exactly what the serial port assignment procedure would be if you were using the same machine to run Upstart and HS3. I understand from reading upstart and spudUPB manuals that the PIM has to be attached exclusively to either one or the other (upstart or HS3).
            Take this a step at a time. Don't assume anything. And if you get stuck you're not done, others are willing to help.
            Dean
            Here is the setup procedure verbatim from Spud's manual: UPB Plug-in - User Guide
            November 27th, 2013, 03:22 PM
            INSTALLATION / CONFIGURATION
            System Requirements:
            This plugin allows HS to communicate and control UPB (Universal Powerline Bus) devices through a serial interface called a PIM (Powerline Interface Module) or the PulseWorx Gateway PGW which is an Ethernet based interface. Here are the only supported interfaces:
            If you need an USB interface go with the PIM-U from PulseWorx. The UMC-DB9 from SA with an additional Serial to USB adapter won't work.
            This plugin is for HS3 or HS3PRO. Both Windows and Linux version are supported. It also can run as a remote plugin, i.e. on a different machine than the one on which HS is running.
            UPB System Configuration:
            Before using this plugin, your UPB system must be configured using the UPStart program that you can download from http://www.simply-automated.com/prod...t_download.php
            The UPStart application will allow you to program and test your UPB devices. When you have completed programming your devices you will need to export your UPB system description so that the plugin can access information about your system. To export your system description use the File/Export command within the UPStart application, and save the file as a .upe file somewhere on your disk, for example in your HS Config folder.
            Plugin Installation:
            Download and install the plugin called UPBSpud from the updater, or download the package from the Beta Testing thread and follow instructions to install.
            Plugin Configuration
            First, make sure you have closed the UPStart program, otherwise the plugin won't be able to communicate with your UPB network.
            Start the plugin from the "PLUG-INS > Manage" page and go to the config page "PLUG-INS > UPBSpud > Config".
            Choose the interface type you have, i.e. "Serial/USB PIM" or "PulseWorx Gateway", then enter the name of the COM Port for the PIM or the IP address of the PGW.
            Click Edit and select your .upe file, then click on the Import button. If everything is ok, it will import your UPB configuration, create HS devices, and synchronize them with the current status of your actual devices.
              - tenholde:
              I will be sure to enable the 'report local changes' parameter when I update my Upstart config file. (and, Biff: This is another feature to add in the beginning.)
              - tenholde and Uncle Michael (and others):
              Since we're talking about how to optimize the Upstart config file, would you please suggest any other parameters that you find useful, or share other lessons you may have learned 'the hard way' while trying to get the most use from UPB through HS3?
              Dean
                -. . .please suggest any other parameters that you find useful, or share other lessons you may have learned 'the hard way' while trying to get the most use from UPB through HS3?
                I found that I needed to install an active repeater at my breaker panel to get reliable communication on both legs of my electrical system.
                http://www.pcslighting.com/pulseworx/products/tools/spr
                  I recommend never changing a device in HS. Make all changes in UpStart. If you change a name in UpStart, delete the device from HS before restarting the plugin. The plugin will find the new device and recreate the HS device.
                  tenholde
                    Uncle Michael
                    Prior to export of the UPB config file, all of them passed the Upstart communications test. I must not have configured them correctly for status reporting.
                    When we turn on lights with HAI UPB wall switches some (all?) of them do not update to 'ON' status in HS3. I confirmed my office light just now. When I activate the light remotely through myHS the light status properly converts to 'ON' in the HS3 device list. When I turn the light 'OFF' manually from the wall switch, the HS3 status indication remains 'ON'.
                    When I initially configured UPB, I had zero experience with both UPB and HS. I did not realize the significance of configuring devices to report local changes. Now am digging in to set things up correctly. I have a bit of desktop workspace excavation to do.... and when I reach the layer of the Upstart laptop and PIM, I will see what's in there .
                    Perhaps I should run Upstart on the HS machine instead. Do you recommend this? When I first created my UPB network, I thought it would be useful to run the upstart config on a portable machine, but with the PIM tied to a power outlet, it was not really a practical strategy. It took two people to enroll upb devices from all parts of the house.
                    Dean
                      I only run UpStart on HS computer. Stop the plug-in, run UpStart, restart plug-in. I do this by remoting in to HS computer via VNC
                      tenholde
                        I do the same. I use RealVNC, which is free and works very well. It allows me to use a small laptop to view the display and control the HS computer from anywhere in the house.
                          Similar to Uncle Michael, I also use an active repeater (a.k.a. 'split phase repeater) at my breaker panel. Mine is from HAI (now Leviton).
                          And tenholde's point is huge: It is so easy to edit parameters of UPB devices and see immeidate functional results in HomeSeer -- therefore it is TEMPTING to make UPB device config changes that one should not make in HS3. It is a trap for the unwary. The Upstart config model is the gold standard. Now I see my current 'heavily-edited' UPB config in HS3 as a practice run, a beta test of my UPB network. I have saved the details and am using the spreadsheet as a reminder as I update my UPB devices in Upstart. I will delete all of my existing UPB devices from HS3 before importing the next version of the UPB network config (export) file from Upstart.
                          Also: BiffMonday, since you are creating your UPB/HS3 'namespace' de novo: In subsequent steps as you build-out your network, whenever 'user friendly' names are needed for Alexa (or similar interfaces), if your fully-descriptive and unambiguous Upstart UPB device names don't work well for your family and guests, you can create virtual devices in HS3 with friendly names, and control the UPB devices through that abstract layer of 'name translators' with as many virtual devices and/or events as needed. Those, you can edit in HS3 whenever you want to change them, or need to change them or add-to them to work with some other network/interface abstraction layer (such as Alexa, etc).
                          It takes some work to wrangle the lower-level details, but being able to unify the entire system under a single set of high-level abstractions is the best part of using a 'neutral' third-party integration interface like HomeSeer.
                          Dean
                            I use MS Remote Desktop to control the HS computer from a Macbook, so the original Win7 Upstart laptop is redundant now, and the PIM can always keep a physical connection to the HS computer serial port.
                              For Alexa control, use JON Alexa helper script and you can specify any request text to do whatever to any HS device. Best way to create abstraction level.
                              tenholde
