Added devices upstart do not show up in HS3
  • Added devices upstart do not show up in HS3
    I added some new devices in upstart, they operate fine and I export all devices for HS3 to utilize.
    On latest HS3 release (not beta) and latest UPB Spud version. Everything else , 20 + devices work just fine.
    They do not show up. I can turn on debug logging, and start the plugin and then send the log file for review as needed.
    What causes this issue and is there a method I can step through to clear this.... otherwise I will send the debug log.
    Where is a good location to email?
    Thanks in advance,
    Richard
    HS3 Standard Edition 3.0.0.258
    Both plugins need the Upstart export file to work. The configuration is bit different with the HS3 version and Spuds version.
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.4X
    Homeseer Zee2 (Lite) - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.4X
      Thanks in advance,
      Richard
      Did you make sure that the .upe file you import to HS3 contains your new devices?
      Also, make sure that the Floor and Room filters on the device management page are all checked.
      If you can't figure it out, send me the debug logs as well as the .upe file at spud.webb.4@gmail.com
        Yes, updated export file was there. .upe . I tried a manual import and checked the HS3 log for startup, but no new devices that I added are in HS3?
