Can't update version of UPBSpud "Install/Update of package UPBSpud failed."
    UPBSpud ver. 3.0.0.47
    Hi I have the same problem 3.0.0.50
    did multiple attempts will not load newest
    version
    let me know if you get it to work
    thanks Biff
      I've seen this, too. It has always been caused by the failure of the .exe to stop when the plug-in shuts down. I have found that if I disable the plug-in, then kill the task (HSPI_UPBSpud.exe) with Task Manager, the update will then install without issue. You could also restart HS after disabling the plug-in, then try the install, since HS forces all the plug-ins to terminate on HS shutdown.
      HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
        First solution worked for me, thank you.
          HS3 v.500 had the same problme
          Stopping the Plug-in
          Downloading new version of Plug-in
          Restarting Plug-in
          Worked for ME!!!
          Devoir
