HS3 v.500 had the same problme
Stopping the Plug-in
Downloading new version of Plug-in
Restarting Plug-in
Worked for ME!!!
Devoir
Can't update version of UPBSpud "Install/Update of package UPBSpud failed."
I've seen this, too. It has always been caused by the failure of the .exe to stop when the plug-in shuts down. I have found that if I disable the plug-in, then kill the task (HSPI_UPBSpud.exe) with Task Manager, the update will then install without issue. You could also restart HS after disabling the plug-in, then try the install, since HS forces all the plug-ins to terminate on HS shutdown.
Hi I have the same problem 3.0.0.50
did multiple attempts will not load newest
version
let me know if you get it to work
thanks Biff
UPBSpud ver. 3.0.0.47
Can't update version of UPBSpud "Install/Update of package UPBSpud failed."Tags: None
