help for a newbie.
    help for a newbie.
    what does this tell you , other than the obvious?
    May-12 4:55:05 PM UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 20 [07140114FF30A1] to PIM -- timed out 5 times -- discarding message
    May-12 4:54:59 PM Device Control Device: Breakfast Room Breakfast Table to On (100) by/from: CAPI Control Handler
    May-12 4:54:42 PM Device Control Device: Breakfast Room Breakfast Table to On (100)
    May-12 4:54:20 PM UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 19 [07140113FF30A2] to PIM -- timed out 5 times -- discarding message
    May-12 4:53:35 PM UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 18 [07140112FF30A3] to PIM -- timed out 5 times -- discarding message
    May-12 4:53:14 PM Device Control Device: Breakfast Room Breakfast Table to On (100) by/from: CAPI Control Handler
    May-12 4:53:05 PM Device Control Device: Great Room Fireplace Lights to On (100) by/from: CAPI Control Handler
    May-12 4:52:50 PM UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 17 [07140111FF30A4] to PIM -- timed out 5 times -- discarding message
    May-12 4:52:05 PM UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 16 [07140110FF30A5] to PIM -- timed out 5 times -- discarding message
    May-12 4:51:20 PM UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 15 [0714010FFF30A6] to PIM -- timed out 5 times -- discarding message
    May-12 4:50:35 PM UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 14 [0714010EFF30A7] to PIM -- timed out 5 times -- discarding message
    Most likely is that the plugin cannot access the PIM.
    What kind of PIM is it? Have you close UPstart before starting the plugin?
      It is a pcs powerline pim. yes, i thought i did. i';ll try it again. i am not getting the error messages like i was before,. but the lights still arent lighting.
      May-12 5:06:39 PM Device Control Device: Great Room Fireplace Lights to On (100) by/from: CAPI Control Handler
      May-12 5:06:34 PM Device Control Device: Great Room Fireplace Lights to On (100) by/from: CAPI Control Handler
      May-12 5:06:28 PM Device Control Device: Breakfast Room Breakfast Table to Blink (-5) by/from: CAPI Control Handler
      May-12 5:06:23 PM Device Control Device: Breakfast Room Breakfast Table to Blink (-5) by/from: CAPI Control Handler
      May-12 5:06:18 PM Device Control Device: Breakfast Room Breakfast Table to Dim 99% (99) by/from: CAPI Control Handler
      May-12 5:06:13 PM Device Control Device: Breakfast Room Breakfast Table to On (100) by/from: CAPI Control Handler
      May-12 5:06:08 PM Device Control Device: Breakfast Room Breakfast Table to On (100) by/from: CAPI Control Handler
      May-12 5:06:00 PM Energy DB Info All energy database compacting routines completed.
      May-12 5:06:00 PM Energy DB Info No Records. Vacuuming database to condense.
      May-12 5:06:00 PM Energy DB Info Energy database compaction initiated.
      May-12 5:05:28 PM Device Control Device: Great Room Rear Floods to On (100) by/from: CAPI Control Handler
      May-12 5:03:18 PM Device Control Device: Great Room Rear Floods to On (100) by/from: CAPI Control Handler
        what mode does the pim need to be in when i turn off the upb? I left it in pulse mode
          do i disconnect the pim from upb when shutting it down?
            Message/Source
            May-12 5:11:34 PM Device Control Device: Great Room Rear Floods to On (100) by/from: CAPI Control Handler
            May-12 5:11:29 PM UPBSpud INFO Checking HS Devices Completed
            May-12 5:11:17 PM UPBSpud INFO Checking HS Devices Started
            May-12 5:11:17 PM UPBSpud INFO Import of UPStart file completed
            May-12 5:11:17 PM Plug-In Finished initializing plug-in UPBSpud
            May-12 5:11:17 PM Starting Plug-In UPBSpud loaded in 516 milliseconds
            May-12 5:11:17 PM UPBSpud INFO Import of UPStart file started
            May-12 5:11:17 PM Starting Plug-In Plugin UPBSpud started successfully in 61 milliseconds
            May-12 5:11:17 PM UPBSpud INFO UPBSpud version 3.0.0.50
            May-12 5:11:17 PM Starting Plug-In Initializing plugin UPBSpud ...
            May-12 5:11:17 PM Info Plugin UPBSpud has connected. IP:127.0.0.1:51542
            May-12 5:11:03 PM UPBSpud INFO Shutting Down UPBSpud plugin
            May-12 5:11:03 PM Plug-In Shutting down Plug-In: UPBSpud
              now i got an error message
              May-12 5:12:19 PM UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 1 [0814011CFF226442] to PIM -- timed out 5 times
                does this look normal
                Status Floor Room Name Last Change Control
                Off
                Great Room Rear Floods On Off Blink Last Level
                Off
                Great Room Fireplace Lights On Off Blink Last Level
                Off
                Foyer Front Floods On Off Blink Last Level
                Off
                Foyer Foyer Light On Off Blink Last Level
                Off
                Dining Room Dining Lights On Off Blink Last Level
                Off
                Breakfast Room Breakfast Table On Off Blink Last Level
                  the pim works when in upb mode. what am i missing
                    make sure you have entered the correct COM port in the Config page
                    are you on Windows or Linux?
                    from the config page set the log level to Debug to get more information
                      copuldnt confirm com port in upb, so changed it form com3 to com1. using windows. web interface. how do i set to debug mode
                        at the bottom of the Config page, the same page you use to enter the COM port, there is "log level" field, set it to Debug
                        also, not sure it is important but I think the com port should be upper case COM3 instead of com3
                          To see your COM ports: In File Explorer (on the HS PC) right click on 'This PC', then select 'Manage'. That will bring up the Device Manager. Select 'Ports (Com & LPT)' to get a list of ports in use. I've noted my UPB port below with the red mark.
                            here is what i am seeing
                              i have the upb pim plugged into a usb port as well as a keyboard and mouse
