Problems with UPBSpud
    UPBSpud doesn't work with Upb links and giving a lot of different errors. With upb devices seems to be work.
    HomeSeer Version: HS3 Pro Edition 3.0.0.548 (Linux)
    UPBSpud 3.0.0.50
    Linux Ubuntu 16.04 LTS
    Nov-06 12:23:24 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message to device succeeded
    Nov-06 12:23:19 PM UPBSpud DEBUG PIM_SEND:: Message ID 8 confirmed sent successfully
    Nov-06 12:23:19 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message marked as being sent, timeout timer has 1 millis left
    Nov-06 12:23:13 PM UPBSpud DEBUG PIM_SEND:: Got UPB Device NAK for LINK messge -- treating it as OK
    Nov-06 12:23:13 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message marked as being sent, timeout timer has 1 millis left
    Nov-06 12:23:11 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
    Nov-06 12:23:09 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message marked as being sent, timeout timer has 1 millis left
    Nov-06 12:23:09 PM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=8)
    Nov-06 12:23:00 PM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[88149019FF20009C ]
    Nov-06 12:22:56 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message marked as being sent, timeout timer has 10000 millis left
    Nov-06 12:22:56 PM UPBSpud DEBUG PIM_SEND:: Sending Message ID 8 to PIM, retry count=0
    Nov-06 12:22:51 PM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 8)
    Nov-06 12:22:51 PM UPBSpud DEBUG PIMADAPTER:: Got update on Confirmed message, but still not sent to PIM yet
    Nov-06 12:22:45 PM UPBSpud DEBUG UPB_MGR:: passing sendConfirmedMessage for UPB message to media-adapter
    Nov-06 12:22:34 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
    Nov-06 12:22:09 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message to device succeeded
    Nov-06 12:22:06 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message marked as being sent, timeout timer has 1 millis left
    Nov-06 12:22:06 PM UPBSpud DEBUG PIM_SEND:: Message ID 7 confirmed sent successfully
    Nov-06 12:22:06 PM UPBSpud DEBUG PIM_SEND:: Got UPB Device NAK for LINK messge -- treating it as OK
    Nov-06 12:22:03 PM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=7)
    Nov-06 12:22:03 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message marked as being sent, timeout timer has 1 millis left
    Nov-06 12:21:59 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
    Nov-06 12:21:58 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message marked as being sent, timeout timer has 1 millis left
    Nov-06 12:21:57 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message marked as being sent, timeout timer has 1 millis left
    Nov-06 12:21:53 PM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[88149017FF20009E ]
    Nov-06 12:21:47 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message marked as being sent, timeout timer has 10000 millis left
    Nov-06 12:21:47 PM UPBSpud DEBUG PIM_SEND:: Sending Message ID 7 to PIM, retry count=0
    Nov-06 12:21:39 PM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 7)
    Nov-06 12:21:39 PM UPBSpud DEBUG PIMADAPTER:: Got update on Confirmed message, but still not sent to PIM yet
    Nov-06 12:21:34 PM UPBSpud DEBUG UPB_MGR:: passing sendConfirmedMessage for UPB message to media-adapter
    Nov-06 12:21:22 PM Device Control Device: 025. 2nd Hall ON to Activate (-2) by/from: CAPI Control Handler
    Nov-06 12:21:19 PM Device Control Device: 023. Dining C to Activate (-2) by/from: CAPI Control Handler
    Nov-06 12:12:57 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
    Nov-06 12:12:39 PM Device Control Device: 014. Kitchen OFF to Activate (-2) by/from: CAPI Control Handler
    Nov-06 12:12:39 PM Error Posting back to plugin web page upbspudconfig: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <285579f54af44a2ca048dad6be20e190>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
    Nov-06 12:12:07 PM Device Control Device: 014. Kitchen OFF to Activate (-2) by/from: CAPI Control Handler
    After some manipulation, one link worked, and another did after 3 minutes, but it gave an error on manage plugin page.
    Plug-in Status CRITICAL: Failed to get InterfaceStatus from UPBSpud: Object reference not set to an instance of an object
    ov-06 12:31:07 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
    Nov-06 12:30:44 PM UPBSpud DEBUG DEVICE[20]:: Level changing on channel 0 from 0 to 100
    Nov-06 12:30:19 PM UPBSpud DEBUG DEVICE[18]:: Level changing on channel 0 from 0 to 100
    Nov-06 12:30:18 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
    Nov-06 12:29:59 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message to device succeeded
    Nov-06 12:29:59 PM UPBSpud DEBUG PIM_SEND:: Message ID 14 confirmed sent successfully
    Nov-06 12:29:59 PM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=14)
    Nov-06 12:29:59 PM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=14)
    Nov-06 12:29:59 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
    Nov-06 12:29:59 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU080F90000586646A]
    Nov-06 12:29:58 PM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
    Nov-06 12:29:58 PM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[8814900DFF2000A8 ]
    Nov-06 12:29:58 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU080E90000586646B]
    Nov-06 12:29:58 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message marked as being sent, timeout timer has 10000 millis left
    Nov-06 12:29:58 PM UPBSpud DEBUG PIM_SEND:: Sending Message ID 14 to PIM, retry count=0
    Nov-06 12:29:58 PM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 14)
    Nov-06 12:29:58 PM UPBSpud DEBUG PIMADAPTER:: Got update on Confirmed message, but still not sent to PIM yet
    Nov-06 12:29:58 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU080D90000586646C]
    Nov-06 12:29:58 PM UPBSpud DEBUG UPB_MGR:: passing sendConfirmedMessage for UPB message to media-adapter
    Nov-06 12:29:51 PM UPBSpud DEBUG DEVICE[5]:: Level changing on channel 0 from 0 to 100
    Nov-06 12:29:50 PM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU080C90000586646D]
    Nov-06 12:29:42 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
    Nov-06 12:29:15 PM UPBSpud DEBUG DEVICE[21]:: Level changing on channel 0 from 100 to 0
    Nov-06 12:29:02 PM UPBSpud DEBUG DEVICE[20]:: Level changing on channel 0 from 92 to 0
    Nov-06 12:28:54 PM Warning Plugin UPBSpud is not responding but it is still running, not restarting yet.
    Nov-06 12:28:45 PM UPBSpud DEBUG DEVICE[13]:: Level changing on channel 0 from 60 to 0
    Nov-06 12:28:44 PM Device Control Device: 013. Kitchen ON to Activate (-2) by/from: CAPI Control Handler
    Nov-06 12:28:29 PM UPBSpud DEBUG DEVICE[11]:: Level changing on channel 0 from 100 to 0
    Nov-06 12:28:23 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message to device succeeded
    Nov-06 12:28:23 PM UPBSpud DEBUG PIM_SEND:: Message ID 13 confirmed sent successfully
    Nov-06 12:28:23 PM UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=13)
    Nov-06 12:28:22 PM UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=13)
    Nov-06 12:28:22 PM UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[881490F1FF2000C4 ]
    Nov-06 12:28:22 PM UPBSpud DEBUG PIMADAPTER:: Confirmed message marked as being sent, timeout timer has 10000 millis left
    Nov-06 12:28:22 PM UPBSpud DEBUG PIM_SEND:: Sending Message ID 13 to PIM, retry count=0
    Nov-06 12:28:22 PM UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 13)
    Nov-06 12:28:22 PM UPBSpud DEBUG PIMADAPTER:: Got update on Confirmed message, but still not sent to PIM yet
    Nov-06 12:28:22 PM UPBSpud DEBUG UPB_MGR:: passing sendConfirmedMessage for UPB message to media-adapter
    Nov-06 12:28:22 PM Device Control Device: 241. All OFF to Activate (-2) by/from: CAPI Control Handler
      what kind of PIM do you use?
