UPB Event Trigger Only Works On First Attempt
    Since migrating to HS4, the UPB event only works upon a re-start of the plugin or restart of HS4. I have a Leviton HLC 6 Button keypad that when a key is pressed should, Arm my home, turn off all the lights and open a garage door. This only works the first time its used or upon a re-start and it's as if the trigger isn't detected by HS4 on future attempts. I have other similar events with other HLC 6 keypads with the same result. As a note the all lights " all off " function always works as that was programmed into upstart.
    Any help would be appreciated, thx
    Try the device value was just set or changed. Repeat key presses probably do not change the value, so the 'Value that Just Changed' trigger is no longer satisfied.
      Thanks Uncle Mike, that worked perfectly. Thanks for taking the time to answer!
