Powerline Interface Module - IP (PIM-IP)
    Does the Powerline Interface Module - IP (PIM-IP) work with this plugin?
    Thanks!
    Who supplies the PIM-IP? Are you referring to the PulseWorx Gateway?
    This is from the User Guide:
    System Requirements:
    This plugin allows HS to communicate and control UPB (Universal Powerline Bus) devices through a serial interface called a
    PIM
    (Powerline Interface Module) or the PulseWorx Gateway
    PGW
    which is an Ethernet based interface. Here are the only supported interfaces:
      Not the Gateway, this: http://www.pcslighting.com/pulseworx...erfaces/pim-ip
      Thanks!
        No the PIM-IP is not supported
        See the user guide for the list of the supported interfaces: https://forums.homeseer.com/forum/li...-in-user-guide
          Dang it. ☹ I hate to spend $150 for a PIM-U when I already have the PIM-IP.
          Have a Happy New Year and please stay safe.
            I too wish you would support the pcs pim-ip.
            But are you sure your plug-in doesn't support the pim-ip? Has anyone tried? I mean the old homeseer upb plug-in works with it and it isn't supposed to.
              I tried it, didn't work. had to bite the bullet. $$$
