I'm using the PulsWorx PGW Gateway with HS4 on a Pi4 and before with HS3 on a Zee2. On both systems, when I start the Homeseer process, the plugin sometimes cannot connect to the Gateway. All attempts afterward to access any of the UPB devices fail. But when I go to the config page and re-import the configuration file, it can connect to the Gateway and access to the devices work.
Here's the log with a complete startup sequence, the Gateway connect error, the re-import of the config file and then successful access to one UPB device. Please note that the Pi box was already running at this point. I started Homeseer from the Linux bash. But I also see this error when restarting the whole box.
4/7/2021 1:54:13 PM HomeSeer Device Control Device: UPB-Light SHOW Hallway to Off (0) by/from: CAPI Control Handler 4/7/2021 1:54:10 PM HomeSeer Device Control Device: UPB-Light SHOW Hallway to On (100) by/from: CAPI Control Handler 4/7/2021 1:53:29 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E0001550553039303030354646303438363030303036390D9D] 4/7/2021 1:53:29 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140505FF30AC ] 4/7/2021 1:53:29 PM Legacy-Plugin UPBSpud DEBUG DEVICE[4]:: Level changing on channel 1 from -1 to 0 4/7/2021 1:53:29 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Sending Message ID 5 to PIM, retry count=0 4/7/2021 1:53:29 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 5) 4/7/2021 1:53:28 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms 4/7/2021 1:53:28 PM Legacy-Plugin UPBSpud DEBUG DEVICE[4]:: Level changing on channel 0 from -1 to 0 4/7/2021 1:53:28 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Device State Change 040000FFFFFFFFFFFFFF 4/7/2021 1:53:28 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E2000A040000FFFFFFFFFFFFFF16E0001550553039303030354646303438 363030303036390D9D] 4/7/2021 1:53:27 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply 4/7/2021 1:53:27 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter 4/7/2021 1:53:27 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Patio Lights (5) 4/7/2021 1:53:27 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Message ID 4 confirmed sent successfully 4/7/2021 1:53:27 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=4) 4/7/2021 1:53:27 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E00003504B0D74] 4/7/2021 1:53:27 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=4) 4/7/2021 1:53:27 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E0000350410D7E] 4/7/2021 1:53:27 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [31000100CD] 4/7/2021 1:53:27 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU090005FF038600006A] 4/7/2021 1:53:27 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E0001550553039303030354646303338363030303036410D96] 4/7/2021 1:53:27 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140504FF30AD ] 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Sending Message ID 4 to PIM, retry count=0 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG DEVICE[3]:: Level changing on channel 1 from -1 to 0 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 4) 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG DEVICE[3]:: Level changing on channel 0 from -1 to 0 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Device State Change 03000032323232323232 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E2000A03000032323232323232B2E0001550553039303030354646303338 363030303036410D96] 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Front Lights (4) 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Message ID 3 confirmed sent successfully 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=3) 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E00003504B0D74] 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud INFO Checking HS Devices Completed 4/7/2021 1:53:26 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=3) 4/7/2021 1:53:25 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E0000350410D7E] 4/7/2021 1:53:25 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [31000100CDE0000350410D7E] 4/7/2021 1:53:25 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored 4/7/2021 1:53:25 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU080505FF02860067] 4/7/2021 1:53:24 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140503FF30AE ] 4/7/2021 1:53:24 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E000135055303830353035464630323836303036370DFF] 4/7/2021 1:53:24 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Sending Message ID 3 to PIM, retry count=0 4/7/2021 1:53:24 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Device State Change 02000000000000000000 4/7/2021 1:53:24 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 3) 4/7/2021 1:53:24 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E2000A0200000000000000000011E0001350553038303530354646303238 36303036370DFF] 4/7/2021 1:53:24 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Resuming sending as we received at least one device message 4/7/2021 1:53:24 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU080405FF02860068] 4/7/2021 1:53:24 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E000135055303830343035464630323836303036380DFF] 4/7/2021 1:53:23 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply 4/7/2021 1:53:23 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter 4/7/2021 1:53:23 PM Legacy-Plugin UPBSpud DEBUG DEVICE[2]:: Level changing on channel 0 from -1 to 0 4/7/2021 1:53:23 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Garden Lights (3) 4/7/2021 1:53:23 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Device State Change 02000000000000000000 4/7/2021 1:53:22 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Message ID 2 confirmed sent successfully 4/7/2021 1:53:22 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E2000A0200000000000000000011E0001350553038303430354646303238 36303036380DFF] 4/7/2021 1:53:22 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=2) 4/7/2021 1:53:22 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E00003504B0D74] 4/7/2021 1:53:22 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=2) 4/7/2021 1:53:21 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E0000350410D7E] 4/7/2021 1:53:21 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [31000100CD] 4/7/2021 1:53:21 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140502FF30AF ] 4/7/2021 1:53:21 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Sending Message ID 2 to PIM, retry count=0 4/7/2021 1:53:21 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU080005FF01866409] 4/7/2021 1:53:20 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 2) 4/7/2021 1:53:20 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E000135055303830303035464630313836363430390DFF] 4/7/2021 1:53:20 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Resuming sending after waiting a refreshing 600ms 4/7/2021 1:53:20 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Pausing because last command expected a reply 4/7/2021 1:53:19 PM Legacy-Plugin UPBSpud DEBUG DEVICE[1]:: Level changing on channel 0 from -1 to 100 4/7/2021 1:53:19 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter 4/7/2021 1:53:19 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Device State Change 01646464646464646464 4/7/2021 1:53:19 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Bathroom (2) 4/7/2021 1:53:19 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E2000A016464646464646464648EE0001350553038303030354646303138 36363430390DFF] 4/7/2021 1:53:19 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Message ID 1 confirmed sent successfully 4/7/2021 1:53:19 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=1) 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E00003504B0D74] 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: PIM ACK'd current message (ID=1) 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [E0000350410D7E] 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: Received Gateway Message [31000100CD] 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: ABOUT_TO_SEND[07140501FF30B0 ] 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud INFO Checking HS Devices Started 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Sending Message ID 1 to PIM, retry count=0 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud INFO Import of UPStart file completed 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: Extracted next message to send from queue (ID 1) 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Pantry Power (1) 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG Product Code/ID: 72 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG Manufacturer Code/ID: 1 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG A new generic UPB Device found!! 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG DEVICE[7]:: Marked device Garage Lights (7) as NON-DIMMING 4/7/2021 1:53:18 PM Legacy-Plugin UPBSpud DEBUG DEVICE[7]:: Marked device Garage Lights (7) as NON-DIMMING 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG UPStart_IMPORT:: Transmit Component Count mismatch on deviceID 7 between import file (0) and device (1) 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG UPStart_IMPORT:: Channel Count mismatch on deviceID 7 between import file (2) and device (1) -- updating device 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG Product Code/ID: 60 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG Manufacturer Code/ID: 1 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG A new generic UPB Device found!! 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG DEVICE[5]:: Marked device Patio Lights (5) as NON-DIMMING 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG DEVICE[5]:: Marked device Patio Lights (5) as NON-DIMMING 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG UPStart_IMPORT:: Transmit Component Count mismatch on deviceID 5 between import file (0) and device (1) 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG UPStart_IMPORT:: Channel Count mismatch on deviceID 5 between import file (2) and device (1) -- updating device 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG Product Code/ID: 60 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG Manufacturer Code/ID: 1 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG A new generic UPB Device found!! 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG DEVICE[3]:: Marked device Garden Lights (3) as NON-DIMMING 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG DEVICE[3]:: Marked device Garden Lights (3) as NON-DIMMING 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG UPStart_IMPORT:: Transmit Component Count mismatch on deviceID 3 between import file (0) and device (1) 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG UPStart_IMPORT:: Channel Count mismatch on deviceID 3 between import file (2) and device (1) -- updating device 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG Product Code/ID: 60 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG Manufacturer Code/ID: 1 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG A new generic UPB Device found!! 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG DEVICE[4]:: Marked device Front Lights (4) as NON-DIMMING 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG DEVICE[4]:: Marked device Front Lights (4) as NON-DIMMING 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG NETWORK[5]:: Added Room [Outdoor] -- 3 rooms now known 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG UPStart_IMPORT:: Transmit Component Count mismatch on deviceID 4 between import file (0) and device (1) 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG UPStart_IMPORT:: Channel Count mismatch on deviceID 4 between import file (2) and device (1) -- updating device 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG Product Code/ID: 60 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG Manufacturer Code/ID: 1 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG A new generic UPB Device found!! 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG NETWORK[5]:: Added Room [Indoor] -- 2 rooms now known 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG Product Code/ID: 72 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG Manufacturer Code/ID: 1 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG A new generic UPB Device found!! 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG DEVICE[1]:: Marked device Pantry Power (1) as NON-DIMMING 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG NETWORK[5]:: Added Room [System] -- 1 rooms now known 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG UPStart_IMPORT:: Transmit Component Count mismatch on deviceID 1 between import file (0) and device (1) 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG Product Code/ID: 15 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG Manufacturer Code/ID: 1 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG A new generic UPB Device found!! 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG NETWORK[5]:: Added Link [Night Lights ON (4)] -- 4 links now known 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG NETWORK[5]:: Added Link [Evening Lights ON (3)] -- 3 links now known 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG NETWORK[5]:: Added Link [All Indoor Lights ON (2)] -- 2 links now known 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG NETWORK[5]:: Added Link [Reboot Pantry Power (1)] -- 1 links now known 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud INFO Import of UPStart file started 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG UPB_RCVR:: TCP Listen Thread started 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG PIM_SEND:: PIM Adapter starting sender thread 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG PGWADAPTER:: Received: AUTH SUCCEEDED/0 CLIENTS 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG PGWADAPTER:: Sending: mikemaster/1385FEF7A65884C02D664EAB7CC5599E 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG PGWADAPTER:: Authentication required 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG PGWADAPTER:: Received: PCS PIM-IP2/1.8/1/AUTH REQUIRED/5851FAF440B182164BB5F89F47033FF0307055DD20FD536D1A8B71A15029 57012B8946B16C03587E08CDB9263477DAE670A3ABF228E4B4287D834F25 0AE16100 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG PGWADAPTER:: Sending: HSPI_UPBSpud/3.0.0.53/1 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: Activating media adapter 4/7/2021 1:53:17 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: Initializing media adapter Comment: After seeing the Gateway error in the Log file, I went to the UPB config page, switched on the Debug log level and clicked on "Import", which runs successfully. After that I was able to switch on/off my Hallway light (see top of log). 4/7/2021 1:52:41 PM Legacy-Plugin Z-Wave Starting Z-Wave Polling for Network E8E127B8... 4/7/2021 1:52:31 PM Legacy-Plugin UPBSpud DEBUG PGWADAPTER:: No route to host 4/7/2021 1:52:31 PM Legacy-Plugin UPBSpud ERROR PGWADAPTER:: Unable to connect to Gateway host=192.168.100.3port=2101 4/7/2021 1:52:16 PM Legacy-Plugin Z-Wave ************************************************************ ******************* 4/7/2021 1:52:16 PM Legacy-Plugin Z-Wave STARTUP COMPLETE: All configured interfaces were successfully initialized. 4/7/2021 1:52:16 PM Legacy-Plugin Z-Wave ************************************************************ ******************* 4/7/2021 1:52:15 PM HomeSeer Startup Start up complete. 4/7/2021 1:52:15 PM HomeSeer Info No device issues found 4/7/2021 1:52:15 PM HomeSeer Info Checking device parent child relationships... 4/7/2021 1:52:15 PM HomeSeer Info Latest BETA update available is: 4/7/2021 1:52:15 PM HomeSeer Info Latest update available is: 4.1.15.0 4/7/2021 1:52:15 PM Script Startup Scripting is OK and is now running Startup.vb 4/7/2021 1:52:15 PM HomeSeer Info Checking for updates... 4/7/2021 1:52:15 PM HomeSeer Startup HSSentry is disabled in Setup, sentry will not be started. 4/7/2021 1:52:15 PM HomeSeer Startup Starting Event Scheduler... 4/7/2021 1:52:15 PM Legacy-Plugin Z-Wave SmartStick: ............................................................ .......... 4/7/2021 1:52:15 PM Legacy-Plugin Z-Wave SmartStick: .............................. FINISHED .............................. 4/7/2021 1:52:15 PM Legacy-Plugin Z-Wave SmartStick: ............................................................ .......... 4/7/2021 1:52:15 PM Legacy-Plugin Z-Wave SmartStick is the SIS for the network. 4/7/2021 1:52:15 PM Legacy-Plugin Z-Wave SmartStick There is a SUC/SIS in the network. 4/7/2021 1:52:15 PM Legacy-Plugin Z-Wave SmartStick Controller is static lib. 4/7/2021 1:52:15 PM Legacy-Plugin Z-Wave SmartStick Controller chip type is ZW050x. 4/7/2021 1:52:15 PM Legacy-Plugin Z-Wave The interface's security support has been set. 4/7/2021 1:52:14 PM Legacy-Plugin Z-Wave SmartStick: Found 21 Z-Wave nodes in interface node ID 1 (SmartStick) 4/7/2021 1:52:14 PM Legacy-Plugin Z-Wave SmartStick: Z-Wave interface node ID: 1, Home ID: E8E127B8 4/7/2021 1:52:14 PM Legacy-Plugin Z-Wave SmartStick: Z-Wave Serial API version: 8 4/7/2021 1:52:14 PM Legacy-Plugin Z-Wave SmartStick: Z-Wave services for the SECURITY COMMAND CLASS were successfully started. 4/7/2021 1:52:14 PM HomeSeer Web Server Web Server authorized login successful from: 192.168.1.214 User: mikemaster 4/7/2021 1:52:13 PM Legacy-Plugin Z-Wave SmartStick: Controller firmware version: 6.1 4/7/2021 1:52:12 PM HomeSeer Startup Running the startup script Startup.vb 4/7/2021 1:52:12 PM HomeSeer Startup HStouch server not started since it is disabled in setup. 4/7/2021 1:52:12 PM HomeSeer Plug-In Finished initializing plug-in UPBSpud 4/7/2021 1:52:12 PM HomeSeer Starting Plug-In UPBSpud loaded in 1101 milliseconds 4/7/2021 1:52:12 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: Activating media adapter 4/7/2021 1:52:12 PM Legacy-Plugin UPBSpud DEBUG UPB_MGR:: Initializing media adapter 4/7/2021 1:52:12 PM HomeSeer Starting Plug-In Plugin UPBSpud started successfully in 166 milliseconds 4/7/2021 1:52:12 PM Legacy-Plugin UPBSpud INFO UPBSpud version 3.0.0.53 4/7/2021 1:52:12 PM HomeSeer Starting Plug-In Initializing plugin UPBSpud ... 4/7/2021 1:52:12 PM HomeSeer Info Plugin UPBSpud has connected. IP:127.0.0.1:39350 4/7/2021 1:52:12 PM Legacy-Plugin Pushover 3P Plugin Started 4/7/2021 1:52:12 PM Legacy-Plugin Pushover 3P Glance Message Delay Value 20 4/7/2021 1:52:12 PM Legacy-Plugin Pushover 3P Starting Flood Control Timer 4/7/2021 1:52:11 PM Legacy-Plugin Z-Wave SmartStick: Getting node information from controller... 4/7/2021 1:52:11 PM Legacy-Plugin Z-Wave SmartStick: The Z-Wave API Execution Thread was Started or Restarted. 4/7/2021 1:52:11 PM Legacy-Plugin Z-Wave SmartStick: The Z-Wave Command Execution Thread was Started or Restarted. 4/7/2021 1:52:11 PM Legacy-Plugin Z-Wave SmartStick: ---------------------------------------------------------------------- 4/7/2021 1:52:11 PM Legacy-Plugin Z-Wave Initializing Z-Wave interface SmartStick (HomeSeer SmartStick +) on /dev/ttyACM0 4/7/2021 1:52:11 PM Legacy-Plugin Z-Wave SmartStick: ---------------------------------------------------------------------- 4/7/2021 1:52:11 PM Legacy-Plugin Z-Wave SmartStick: ============================================================ ========== 4/7/2021 1:52:11 PM Legacy-Plugin Z-Wave 465 Simple AV Control Command Class Control Commands have been loaded successfully. 4/7/2021 1:52:11 PM HomeSeer Plug-In Finished initializing plug-in Z-Wave 4/7/2021 1:52:11 PM HomeSeer Starting Plug-In Z-Wave loaded in 2806 milliseconds 4/7/2021 1:52:11 PM Legacy-Plugin Z-Wave 0 event triggers were loaded from HomeSeer. 4/7/2021 1:52:11 PM Legacy-Plugin Z-Wave 0 event actions were loaded from HomeSeer. 4/7/2021 1:52:11 PM HomeSeer Starting Plug-In Plugin Z-Wave started successfully in 2023 milliseconds 4/7/2021 1:52:10 PM Legacy-Plugin Z-Wave 60 total Z-Wave Data Objects loaded. 4/7/2021 1:52:10 PM Legacy-Plugin Z-Wave Network E8E127B8 has 60 device data elements. 4/7/2021 1:52:10 PM Legacy-Plugin Z-Wave 1 Networks were restored from the data in the database... Building data connections. 4/7/2021 1:52:10 PM Legacy-Plugin Z-Wave Loading Z-Wave Data Objects... 4/7/2021 1:52:10 PM Legacy-Plugin Z-Wave 1 total Z-Wave Network Objects loaded. 4/7/2021 1:52:10 PM Legacy-Plugin Z-Wave Loading Z-Wave Network Objects... 4/7/2021 1:52:09 PM Legacy-Plugin Z-Wave Database: Opening (Mode=Read Only) up HomeSeer database /usr/local/HomeSeer/Data/Z-Wave/Z-Wave2.db 4/7/2021 1:52:09 PM Legacy-Plugin Pushover 3P Attempting To Produce a Client/Group List 4/7/2021 1:52:09 PM Legacy-Plugin Pushover 3P Downloaded 23 sounds from Pushover - Adding Device Default 4/7/2021 1:52:09 PM Legacy-Plugin Z-Wave InitIO called, plug-in version 3.0.2.0 is being initialized... 4/7/2021 1:52:09 PM HomeSeer Starting Plug-In Initializing plugin Z-Wave ... 4/7/2021 1:52:09 PM HomeSeer Info Plugin Z-Wave has connected. IP:127.0.0.1:39346 4/7/2021 1:52:08 PM Legacy-Plugin Pushover 3P Downloading sounds from Pushover 4/7/2021 1:52:08 PM HomeSeer Plug-In Finished initializing plug-in Pushover 3P 4/7/2021 1:52:08 PM HomeSeer Starting Plug-In Pushover 3P loaded in 901 milliseconds 4/7/2021 1:52:08 PM HomeSeer Starting Plug-In Plugin Pushover 3P started successfully in 38 milliseconds 4/7/2021 1:52:08 PM Legacy-Plugin Pushover 3P Plugin Starting - Starting Thread 4/7/2021 1:52:08 PM HomeSeer Starting Plug-In Initializing plugin Pushover 3P ... 4/7/2021 1:52:08 PM HomeSeer Info Plugin Pushover 3P has connected. IP:127.0.0.1:39340 4/7/2021 1:52:07 PM HomeSeer Startup Initializing Plug-Ins 4/7/2021 1:52:07 PM HomeSeer Plug-In Found plug-in: Z-Wave, version: 3.0.2.0 4/7/2021 1:52:06 PM HomeSeer Plug-In Found plug-in: UPBSpud, version: 3.0.0.53 4/7/2021 1:52:06 PM HomeSeer Plug-In Found plug-in: Pushover 3P, version: 0.0.0.34 4/7/2021 1:52:05 PM HomeSeer Startup Checking for available plug-ins 4/7/2021 1:52:05 PM HomeSeer Info Remote plug-in API interface started on port 10400 4/7/2021 1:52:05 PM HomeSeer Startup Starting Find service... 4/7/2021 1:52:05 PM HomeSeer Startup Updater services starting... 4/7/2021 1:52:05 PM HomeSeer Speech Listening for remote speaker connections on port 10401 4/7/2021 1:52:05 PM HomeSeer Startup Initializing Speaker Client Interface 4/7/2021 1:52:05 PM HomeSeer Startup Start automation engine... 4/7/2021 1:52:05 PM HomeSeer Web Server Web Server started on port 80 4/7/2021 1:52:05 PM HomeSeer Web Server Local IP address is: 192.168.100.22 4/7/2021 1:52:05 PM HomeSeer Startup This version of HomeSeer is registered as a HS4ZEES2_PIHUB version. 4/7/2021 1:52:05 PM HomeSeer Startup Creating Speaker Client Interface Object... 4/7/2021 1:52:05 PM HomeSeer Startup HomeSeer version is: 4.1.14.0 4/7/2021 1:52:05 PM HomeSeer Info Loaded 2 Timers. 4/7/2021 1:52:05 PM HomeSeer Info Loaded 1 Counters. 4/7/2021 1:52:05 PM HomeSeer Info Loaded 48 Events. 4/7/2021 1:52:04 PM HomeSeer Info Loaded 136 Devices. 4/7/2021 1:52:03 PM HomeSeer Startup Loading configuration file ... 4/7/2021 1:52:03 PM HomeSeer Startup Local voice recognition class started. 4/7/2021 1:52:03 PM HomeSeer Startup Plug-In Interface class started. 4/7/2021 1:52:03 PM HomeSeer Startup E-Mail RECEIVE class started. 4/7/2021 1:52:03 PM HomeSeer Startup E-Mail SEND class started. 4/7/2021 1:52:03 PM HomeSeer Startup Web server class started. 4/7/2021 1:52:03 PM HomeSeer Startup Application interface class started. 4/7/2021 1:52:03 PM HomeSeer Startup COM port classes started. 4/7/2021 1:52:03 PM HomeSeer Startup Creating Class Objects... 4/7/2021 1:52:03 PM HomeSeer Startup 4/7/2021 1:52:03 PM HomeSeer Startup ************************************************************ ******************** 4/7/2021 1:52:03 PM HomeSeer Startup HomeSeer version 4.1.14.0 Edition: HS4 ZEE S2/PI Starting Now 4/7/2021 1:52:03 PM HomeSeer Startup ************************************************************ ******************** 4/7/2021 1:52:03 PM HomeSeer Startup 4/7/2021 1:52:02 PM HomeSeer Startup Settings Loaded. 4/7/2021 1:52:02 PM HomeSeer Startup Loading Settings
