Parse Error importing UPE file.
    Hi. I bought the hardware and I'm testing the plugin. However, I can't get past trying to import my UPB file. I'm getting the errors below in the log when trying to import the upe file I exported from UpStart. The file path is correctly set on the Pi. UPE file attached. The same file works fine when I tested it with the generic HS UPB plugin. I removed the generic plugin after testing by restoring a backup without the plugin and UPB devices, so I know there is no conflict with that plugin.
    Thanks in advance for any help.
    6/18/2021 5:12:00 PM Legacy-Plugin UPBSpud ERROR Import of UPStart file failed
    6/18/2021 5:12:00 PM Legacy-Plugin UPBSpud ERROR UPStart_IMPORT:: Error parsing UPB import file -- Index was outside the bounds of the array.
    6/18/2021 5:12:00 PM Legacy-Plugin UPBSpud INFO Import of UPStart file started
    6/18/2021 5:11:15 PM Legacy-Plugin UPBSpud ERROR Cannot read UPStart export file: /usr/local/HomeSeer/Config/HomeSeer.upe
    6/18/2021 5:10:08 PM Legacy-Plugin UPBSpud ERROR Import of UPStart file failed
    6/18/2021 5:10:08 PM Legacy-Plugin UPBSpud ERROR UPStart_IMPORT:: Error parsing UPB import file -- Index was outside the bounds of the array.
    6/18/2021 5:10:08 PM Legacy-Plugin UPBSpud INFO Import of UPStart file started
