Originally posted by tenholde
View Post
I thought of that as I left the house this morning. So, deleting the devices and reimporting them was one of the first things I did when I got home. Sucess - Problem Solved!!
Uncle Michael... Yes, these were replacements of old SA switches (with the same IDs that were NOT set up to dim.) Apparently, HS did not refresh the devices with the correct info during the import, but deleting them and reimporting got everything straightened out. Lesson learned... if the switch configuration changes, then deleting the old device reimporting is the way to go.
Thanks to both of you for the replies.
