SA US22-40T two channel switch incorrectly updating channel status
    When HS device for CH1 is turned ON via the HS Device page, CH2 is also turned ON. That is, both HS devices change their status to ON. Only the physical device for CH1 is turned ON, not the physical device for CH2. I've attached a debug log and the upe file. [ATTACH]n1616565[/ATTACH]
    tenholde
    I may have found the problem, but to confirm could you post 2 debug logs:
    - one where you turn On CH1
    - one where you turn On CH2
    both starting with the 2 channels being off.
    thanks
      Here are the logs for turning each Channel ON when both were OFF.
      tenholde
        Please test version BETA 3.0.0.55.
          Where do I find the beta?
          Update: I found it
          tenholde
            The beta appears to resolve the problem. Thank you for the quick response.
            tenholde
